jackrory Posted December 15, 2006 Report Share Posted December 15, 2006 hello, can i get some advice on tyre pressure please... my b6 avant 2.0 fsi is on dunlop 17inch..the alloys are from the b7 A4(five spoke design)..ride seems kind of hard and steering a little unresponsive...what PSI should i try for this car..thanks Link to comment Share on other sites More sharing options...
Cupramax Posted December 15, 2006 Report Share Posted December 15, 2006 Tyre pressures should be on a sticker either on the drivers door frame of the fuel filler cap... from memory I think mine are 33 front 30 rear not heavily laden. Not sure if the avant are any different. Link to comment Share on other sites More sharing options...
jackrory Posted December 15, 2006 Author Report Share Posted December 15, 2006 thanks..i'll have a look for the sticker Link to comment Share on other sites More sharing options...
spikeyboy Posted December 15, 2006 Report Share Posted December 15, 2006 not sure what use it is but in my B6 S4 with 18inch wheels tyre pressure is 39 psi all round for up to 3 passangers. Link to comment Share on other sites More sharing options...
jackrory Posted December 15, 2006 Author Report Share Posted December 15, 2006 hey spikeyboy, i usually travel with 4, 2 little ones in the back..does it really make a huge difference..if its 33 all round or 39...as you can probably tell i have no clue about tyres at all Link to comment Share on other sites More sharing options...
spikeyboy Posted December 15, 2006 Report Share Posted December 15, 2006 As has been mentioned above the tyre pressures will be listed in a panel either inside the frame of the drivers door or on the petrol flap - you cant miss it. All cars are different on the tyre pressures so you do need to check what yours should be. The list will have two settings for both front and rear - one for up to 3 passangers and one for more (has little pics) it also lists the pressures in PSI and BAR - so make sure you have it set right. I run on the lower setting with two adults and two litte ones. Trust this helps Link to comment Share on other sites More sharing options...
jackrory Posted December 15, 2006 Author Report Share Posted December 15, 2006 thanks:) Link to comment Share on other sites More sharing options...
