engine misfire
latif
hi all
gt a 96 4.2
last night car started to misfire .
was parked up waiting fo a friend with engine running.
al of a sudden car started to shake . cat light started to flash. gave the engine a rev and got some misfireing.
today pluged in vag com .
came up with cylinder 4 misfire.
removed n.o 4 coil and plug .plug was soaked in fuel.
decided to swap n.o 4 coil and plug with n.o 1 coil and plug.
started car and same thing was happening ,misfire on n.o 4 cylinder. removed other coil plugs one at a time and found engine rpm would drop but nothing on n.o 4 cylinder .
decided to do a compresion test on cylinder n.o 4 . got arround 150 psi .cant be a burnt valve .
next checked coil plug for power . 3 wires in plug . got a positive and negative but in the third wire nothing
not sure wat to do
please help
thanks
latif
  • 2 weeks later...
  • 4 weeks later...
What was the outcome to this? - I have *exactly* the same problem on my 1998 S8... In my case its cylinder 2 misfiring, then cylinders 4 and 7 go out.... Switch off for 15 mins, switch on and its ok for another 400 miles or so and it does it again.... Very strange....
<VAG COM>
Control Module Part Number: 4D0 907 557 N
Component and/or Version: 4.2L V8/4V MOTR AT D01
Software Coding: 04373
Work Shop Code: WSC 02314
6 Faults Found:
16705 - Engine Speed Sensor (G28): Implausible Signal
P0321 - 35-10 - - - Intermittent
17610 - Fuel Injector for Cylinder 2 (N31): Electrical Malfunction
P1202 - 35-10 - - - Intermittent
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-10 - - - Intermittent
16686 - Cylinder 2: Misfire Detected
P0302 - 35-10 - - - Intermittent
16688 - Cylinder 4: Misfire Detected
P0304 - 35-10 - - - Intermittent
16691 - Cylinder 7: Misfire Detected
P0307 - 35-10 - - - Intermittent
  • 2 weeks later...
