Broadband router of non-joy
ACA_Chap
Evening everyone.
I have a problem with my BT Voyager ADSL router, which I hope someone can solve.
Basically, I had to reformat my PC and reinstall windows on it. That went fine, and the wireless router still works with my wireless laptop no problem.
But,
My desktop PC can't connect to the internet (it is wired to the router). I think this might be to do with the IP settings (I selected obtain IP address automatically).
I don't have the installation disk anymore ROLLEY~14.GIF, so does anyone have any bright ideas?
Thanks in advance
have you logged into the router??
Check the ip address of the gateway on your laptop, click the icon in your tray or look at the wireless card in network connections, see what the gateway is.
Then log into the router by typing this in your web browser.
See if it says your pc is connected.
You don't need any drivers of sotware for a router, and generally I wouldnt put them on anyway, just let windows handle it all, otherwise whn you get problems you have two areas where something could be wrong, if that makes sense?
Are you connected via a network card or USB between wired PC and router?
It's a USB
Have you redone the wizard, which will renew / find IP address?
Sorry to be thick, but which wizard are you talking about. I'll I've done is reformat the PC and put windows back on.
Hi Gizze. No I don't think I have and that's the problem.
I checked what IP address my laptop had and then put this into the desktop PC browser, but no joy. Are you saying I should do this with the default gatweay? Sorry, I really don't know much about IT..
So the router should just be plug and play?
When you say you are connected by USB I am totally lost, did you mean by ethernet cable??
Or maybe you can hook this router to a usb port and load up drivers?? if this is the case then you will need to find those drivers, however I would hook it up via the ethernet port anyway, far easier and you won't have to 'dial in' as it were.
Have you got a network card in your pc??
have you get a network cable somewhere??
If you hook it up via ethernet cable I bet it will work straight away.
Gizze I've tried using a standard ethernet cable direct from the router to the PC.
Still no joy.
It recognises the connection - if i go to connections>show all connections, there's a 400mbps connection running.
It's just internet explorer won't work - probably something to do with IP settings (I've set to find automatically).
Thanks Daz. BTW, off topic I know, but I think I may have seen you in Bournemouth a couple of months ago.
The laptop says loads of stuff:
Physical address, DHCP enabled (yes), auto config enabled (yes), numbers for: IP address, subnet mask, default gateway, DHCP server and DNS servers.
For the desktop:
Just says: "windows IP configuration"
Evening everyone.
But,
Thanks in advance
Have you checked your device manager to see if your PCs ethernet card is installed & active?
In the past when I've re-installed XP the drivers for sound, LAN, VGA etc dont automatically re-install, so you need to add them from the drivers & utilities disc?
Guest
Reply to this topic...
  Only 75 emoji are allowed.
