WHICH AFTERMARKET HID KIT - HIDS4U OR VAGPARTS ?
PANACEA
OK, after driving back from Yorkshire last night, I have decided to take the plunge and get an HID upgrade for my A4 as the standard lights, even with Silver Star bulbs just dont provide enough light in my opinion for safety.
So, after reading all the posts, it seems either HIDS4U or VAGPARTS is the way to go, so just wondered who has used what and if anyone can recommend one over the other.
Thanks, and Happy Christmas.
The bits from Kuftec are sensors that are mounted to the suspension (all 4 corners) which send information to the Xenon control unit about the cars inclination. The control unit will then adjust the headlamp aim to avoid the beam being too high (i.e. if you are going over a small bridge, it'll dip the beam down to keep it level and not blind oncoming drivers).
If you just fit a HID kit, you don't have this feature. In my opinion though, I've never had issues with blinding other drivers. If absolutely necessary, I'll use the manual adjustment switch.
I think HID kits are a great idea if you have the projector style headlamps (as they have a more defined beam cutoff and don't blind oncoming traffic). But I've recently seen so many people with normal headlamp units who have fitted HIDs and not only do they look awful, but they do blind oncoming traffic. openfire.gif
I've bought a kit from ACEParts. Got the details from the guys over on the Pistonheads forum.
£125 for the kit, very nice 169144-ok.gif If you email Alan at ACEparts and mention Pistonheads or PM me for his details. I believe he makes a lot of the kits for the aftermarket suppliers (hence the price!)
I'm hoping to get the kit installed today, if I can get out my dressing gown !
P.
linky
i was going to do the HID upgrade from Vagparts but was warned that it could trip the bulb failure on the DIS all the time when i spoke to Martin at Vagparts he confirmed that the HID upgrade they sell would proberly trip the Bulb failure.
so i have never bothered with them i wish this wasnt the case as the look so much better than just a bulb upgrade has anyone ever done a HID upgrade and found the bulb failure on the DIS to work OK.
Ah yes didn't know there was now a kit for the levelling. Great in the B6 ( factory fit) to watch them level when it starts up in the dark
Are you sure this is correct? The OE set up only has two sensors (1x F&R) and self levels at start up but AFAIK isn't dynamic (adjusts on the fly).
It's partly correct - there's only 2 sensors, one on the front suspension and one on the rear suspension.
I've seen the headlamp beam adjust as I've loaded a heavy weight into my Avant, so I think there's some dynamic adjustment but not sure how much.
Guest
Reply to this topic...
  Only 75 emoji are allowed.
