S4 - Strange Noise
S3Mark
I have just changes my S3 for a 2003 S4, but not sure if there is a problem with it. At lower speeds (<50) it appears to come from the front and sounds as if I am running over some small rumble strips, not disimilar to the noise on the concrete section roads. Even on reasonable roads this happens. Its not really loud and cannot be heard at speeds above 60.
Is this something I should worry about or is this normal?
Tricky, noises are kind of subjective things. It maybe worth just running your hands over the front tyre tread surfaces - if they feel 'ratcheted', i.e. some of the tyre blocks seem to be sticking up further than others then you have one of the indicators of worn front shocks. You have a high performance vehicle there - it would be worth getting a pukka Audi dealer to give it the once-over for safety's sake.
JC think it may have been my post on the 246 forums as i had the same sound from front pasanger side - took ages for the dealer to actually agree to change the wheel bearing but it did the trick.
I think he meant silver ones. The total number of B6 S4s on here could be into double figures now I think! 169144-ok.gif
As does Drewcam, so if you take into accout all S4's regardless of model there must be nearly 20 in all.
Yeah and i fecking love it to bits. I know it sounds a bit anal but i was out at the indian resteraunt tonight and made sure i could see it from the window and i just love the way it looks (me sad) yelrotflmao.gif
I can think of the following...
ScoTTy
Sam_D
Tizzy
J_C
Rottenbend
SpikeyBoy
Will22
MacDond
Me (P_G)
S3 Mark
Merlot?
Pincher?
CosmicBlue
Who am I missing?
I (Cosmicblue) don't have an S4...........I looked at doing a lease purchase on a Cab version a couple of years back and it seemed that Audi knew something that we didn't blush.gif and I abandoned the idea..... frown.gif
Still have my S4 but the RS4 is coming next week as soon as the DVLA get around to sorting the plate change over..
Back to the topic of this, I had my chain tensioners changed under warranty as have some others I think. Symptoms a rumbling or ratling at cold start up or slow speed in a high gear...
Its not fatal, its just annoying and now an updated part although I have seen B7's in for chain tensioners also..
  • 2 weeks later...
Guest
Reply to this topic...
  Only 75 emoji are allowed.
