brake lights
jackrory
This may just be bad luck or you may have a problem such as a loose connection (this would increase resistance and current flowing through the circuit and second to the fuse the bulb is the weakest point)
It is unlikely a power surge is causing this problem but blown bulbs is a common symptom - it would be strange especially to pick on the same bulb twice.
Change it once more to see for certain if there is a recurring problem
The theory goes.............. if you touch a glass light bulb with your bare fingers you will leave oils (from your skin) on the glass which when heated will burn and cause premature failure of the bulb.
This is certainly true of all high temp lighting such as halogen and applies in motor and domestic situations.
I shouldn't worry about side light, brake light etc - they do not get hot enough.
I've just changed one rear bulb last week but only the one; will do a little experiment to see how long it lasts having not changed both rear bulbs at the same time.
I see what you are getting at Will, somrthing along the lines of uneven impedance means increased electrical wear rate, however this might only be true of higher volt system, 12v and above. the rear lights are only 5v so I don't know whether that will make any significant difference.
Will soon find out though!
And impedance is not a correct term - how the feck can a bit of grease interfere with the voltage and current?
I think you'll find that the problem is due to the non-uniform heating of the higher wattage bulbs, such as a 55w halaogen headlamp bulb. The grease acts as a heat sink and the glass of the bulb expands at different rates..... 169144-ok.gif
Not sure there was a suggestion of this ? You are correct in your statement about the grease acting on the lamp glass when heated
UBM, I wasn't on about the grease on a bulb from someones finger, one of the original posts was about replacing both bulbs at the same time even if only one had blown and the reason why you would do this rather then replace just the blown one.
The grease on bulb bit was potentially another problem / reason why the replaced bulb may blow within the three week timescale originally posted if not fitted with minimal contact from ones sticky mitts.
Guest
Reply to this topic...
  Only 75 emoji are allowed.
