For Sale: 450bhp Impreza, 180mph+
AudiPartner
The car started life as 2.0 WRX UK300 limited edition, fitted from new with the Prodrive Performance Pack. The car is edition 161 of the 300.
Then the moddifications began (not by myself, but by the original owner). When I acquired the car it was a 2.5 running just under 400 bhp, and just under 400 lb/ft of torque.
Since owning the car I have had a full rebuild at API (£6k) and now the car is running 452bhp and 477ft/lb of torque (at 1.5 bar). The car has done approximately 2000 miles on the new engine and clutch, and around 300 miles on the new disks.
I have also fitted a single din Alpine stereo and used a Forester CD pocket to fill the hole! The car also has aftermarket speakers fitted in all doors.
The current spec is as follows:
2.5 USA EJ257 short motor
STi 5 Heads
Wiseco Forged Alloy Pistons
Steel Eagle Con Rods
STi Type USA crank
Competition bearing set
740cc Injectors
STi Manifold
Kevlar Cam Belt
APS Front Mount Intercooler
Roger Clark Induction kit
Roger Clark Headers with 3.25" Pat spec exhaust
EcuTek - Mapped by Bob Rawle
Exeedy Clutch (new)
6 Speed STi gearbox
MD321T Turbo charger (new)
AP Racing 330mm Disks with Ferrodo pads(new)
Knock/Lambda Links
HID Fog Lamps
Prodrive Mudflaps
65k miles.
The car is currently fitted with the standard WRX spoiler. However, it used to sport the original WRC spoiler off the 2001 World Rally Car (as seen in one of the below pictures). This spoiler has also been signed by both Tommi Makinen and Petter Solberg so is a real piece of memorabilia. It is not currently on the car, but it can be supplied (not fitted) for £500 on top of asking price. It is also for sale separately.
The car is located in Bromley, Kent.
Asking Price: £13,000
[email protected]
Erm, im a big scooby fan and a even bigger solberg fan, i would love to buy the spolier from you if you supplied the pics of him signing it, i have a great collection of bits of his cars from when he has crashed.
What would you take for it??
would love the car also, but just bought my a4 for 17k and spent a few k on it and dont think id recoup it!
  • 2 weeks later...
  • 3 weeks later...
Is it actually possible for a scooby's gearbox to get to 180 MPH with the ratios before the engine redlines.....mmm not sure it would be tbh. Car looks nice tho..
How long realistically will a 2 litre engine at 450BHP actually last ?..... imo not very long, please correct me if im wrong...
Here are the stats from my mapping when the car was running 420bhp. Now it is running 450 I'm guessing they will be slightly higher.
Top Speed in 1st Gear: 37.4mph
Top Speed in 2nd Gear: 57.2mph
Top Speed in 3rd Gear: 77.2mph
Top Speed in 4th Gear: 101.0mph
Top Speed in 5th Gear: 139.9mph
Top Speed in 6th Gear: 179.7mph
Terminal velocity due to power: 191.7mph
Its the 6th gear that looks special.
Not geting to 60 in 2nds a bit anoying.
Still I bet it still does it stupidly fast.
It probably does now. These figures were based on my previous power figures of 420/440 (ish). Now I have 452/477. That should give me an extra couple of mph's in each gear!! wink.gif
grin.gif Surely only an increase in RPM limit or a change in gear ratio give you more MPH in a gear? Having more ponies or torques just gets you quicker to the same speed as before 169144-ok.gif
Thats right.
Maybe the gearing or rev limiter was increased?
That will be my lack of mechanical knowledge shining through! smashfreakB.gif
So tell me...
My car has a top speed of around 180mph. If I took off my turbocharger and changed it for a lesser rated one, say of 300hp, if everything else on the car remained the same, surely my top speed would be less?? Surely a 450hp car would give a higher top speed than a 300hp car?
So tell me...
well.......
If you removed all friction, the only thing that would limit top speed would be the final gear ratio and max RPM (as faster engine turns, faster the wheels will turn).
Power and Torque are what over come the friction.
So tell me...
In terms of the Impreza then yes @ 300bhp it would be slower and wouldn't be limited by gearing since the drag and frontal area are probably too much for it to get anywhere near 180mph with 'just' 300bhp. With 300, my guess would be about 165mph and with the 450bhp and longer gearing you might get about 180-185mph (but you would need a long road and it would probably feel like a shuttle re-entry EEK2.GIF).
As a comparison, a C32AMG (rather good aerodynamically in terms of slipperyness) can supposedly get to 185ish with just 340 odd bhp. If de-limited then it isn't hampered by the gearing in the same way as your Impreza, plus it doesn't have a barn door wing, bluff front spoiler etc.
Guest
Reply to this topic...
  Only 75 emoji are allowed.
