gannaza Posted March 13, 2007 Report Share Posted March 13, 2007 Hi I am trying to fing the location of a split/solderjoin/connector in the wiring fron the stop light switch to the rear light, the problem is the dash light for the coils flashes ans the esp is on solid. through a bit of research i found it to be likned to the stoplight switch. the high level brake light works but the lower ones l/r do not, i have a haynes book this shows a connection or solder joint in the wire, then 1 goes to the high brake light 1 each the the lower and 1 the the tcs/abs , hense the other light on the dash, but i dont know where this split/ connection in the wiring is. thanks carl Link to comment Share on other sites More sharing options...
Rustynuts Posted March 13, 2007 Report Share Posted March 13, 2007 You have checked the bulbs I presume? Link to comment Share on other sites More sharing options...
gannaza Posted March 13, 2007 Author Report Share Posted March 13, 2007 Hi yes all the bulbs are ok Link to comment Share on other sites More sharing options...
