A4B6 Posted March 13, 2007 Report Share Posted March 13, 2007 Ive got a mk4 golf with original VW MFD sat nav. The map on it is slightly behind my actual position. At the moment ive tried to different copied CD's and the map is still behind. If i get an original CD, do you think it will solve the problem? Link to comment Share on other sites More sharing options...
PetrolDave Posted March 13, 2007 Report Share Posted March 13, 2007 Nope. I think this is a question I've answered many times on many websites ... it takes the GPS receiver a sizeable fraction of a second to calculate your position, ... and by then you've moved on! So the position that any GPS system shows will always be slightly behind where you actually are, and the faster you go the more behind it will be. Link to comment Share on other sites More sharing options...
A4B6 Posted March 13, 2007 Author Report Share Posted March 13, 2007 Its not by abit, its be 50-100 yards. Ive was told that the MFD's laser has to work overtime to read a copied disc so thats why its behind. Link to comment Share on other sites More sharing options...
shark_90 Posted March 13, 2007 Report Share Posted March 13, 2007 Dave, should the MFD take a speed signal from the ABS like in an Audi? Maybe there's a problem there? Link to comment Share on other sites More sharing options...
PetrolDave Posted March 13, 2007 Report Share Posted March 13, 2007 [ QUOTE ] Dave, should the MFD take a speed signal from the ABS like in an Audi? Maybe there's a problem there? [/ QUOTE ] Yes, even most of the aftermarket in-dash sat nav systems need a speed signal - at least all the ones I've fitted did! If it's 50-100 yards behind then it sounds like the speed pulse needs calibrating. The RNS-E auto-calibrates, but it takes a few hundred miles to do so - probably the same on the MFD. Link to comment Share on other sites More sharing options...
Froggy Posted March 14, 2007 Report Share Posted March 14, 2007 It will be the speed pulse calibration I suspect. The older systems only use the GPS information as a check about once every 60 - 90 seconds to compare the calculated position against where the GPS thinks you are. Does the countdown bar accurately tell you when you have reached your turning? And what scale are you looking at the map on? (On fully zoomed in they never keep up, they always appear slightly behind) Link to comment Share on other sites More sharing options...
A4B6 Posted March 14, 2007 Author Report Share Posted March 14, 2007 When in map mode, the countdown bar is about 90% accurate. When i zoom in the most which is 0.1mile and sometimes 0.2 miles, only then the map is behind my actual position. Link to comment Share on other sites More sharing options...
