retro fit front centre arm rest on Golf GT MKV
smipx013
Hi Paul,
I've not done it but I believe I've read that it can be done. Maybe worth checking with VW parts dept to see what they would charge. You'll also need to make sure that the arm rest fabric matches your intereior too.
If I remember correctly, fitting it isn't too difficult but don't expect the rear air vents to work! Maybe worth doing some searches on here as I'm sure it's been done and featured before 169144-ok.gif
  • 4 weeks later...
Hmm from my experience asking VW to do it can cost ya £400 odd - the whole centre console is actually different and requires replacing in order to hold the arm rest and its box.
You may find it cost prohibitive but worth a call to the parts dept of the local VW dealer.
Good luck with it!
Yes it can be done, Parts are around £250ish, You can also buy the ducting for a bit mor to make the rear air vents work!
We have fitted a few now, the only problem is the labour time to do it is about 3.5 hours usually have to take the seats out also to do!
