R32Geordie Posted March 15, 2007 Report Share Posted March 15, 2007 I'm heading out down south this weekend to do a bit for Comic Relief in Milton Keynes and also for a few beers in Oxford. I will therefore put a few miles on the car so I filled up last night, and also decided to check the oil and tyres. I noticed that the tyre pressures inside the filler flap are Metric and should be 2.8 Bar for a non fully loaded car. This equates to 41 PSI. I must admit this is the first time I've checked the tyre pressures They were all at 32PSI and I bet they were filled at that pressure. The car instantly feels more agile and quicker but 41PSI... is this correct ??? Cheers Link to comment Share on other sites More sharing options...
OliFH Posted March 15, 2007 Report Share Posted March 15, 2007 Not sure about the tires - but watch your car in Oxford! There is a one man car crimewave (even got himself on TV a while back!), and if he's not being detained by her majesty at the moment he'll be all over your car! Link to comment Share on other sites More sharing options...
ChrisBuer Posted March 15, 2007 Report Share Posted March 15, 2007 Yes, 40psi is spot on. Either 2.8 bar or 40psi is what's recommended for these tyres! I run mine at these levels and the car feels great!! Link to comment Share on other sites More sharing options...
R32Geordie Posted March 15, 2007 Author Report Share Posted March 15, 2007 I am certian that all 4 tyres have not lost exactly 9 PSI each since I've had the car. The car was therefore delivered with the wrong pressures and I didn't think to check I've been driving for the last year on underinflated tyres !! Honestly, with 41PSI in each corner it's like having a new car. I would urge all MkV R32 owners to double check their tyre pressures. Thanks for help again chaps. Link to comment Share on other sites More sharing options...
Decked Posted March 15, 2007 Report Share Posted March 15, 2007 When I got my tyres changed, I checked that the tyres had been inflated fully. They told me they had...... I checked while I was there they were miles off! They couldn't believe how much the R tyres needed! (mines a Mk4 but by the sounds of things the Mk5 is the same) I recon they didn't infate them properly Link to comment Share on other sites More sharing options...
petsy Posted March 15, 2007 Report Share Posted March 15, 2007 [ QUOTE ] I've been driving for the last year on underinflated tyres !! [/ QUOTE ] hmm, you should really check your pressures at least monthly... Link to comment Share on other sites More sharing options...
Mattchaps Posted March 15, 2007 Report Share Posted March 15, 2007 What pressure are MkIV owners running their's on?? I would have thought it should be about the same Link to comment Share on other sites More sharing options...
Tonsko Posted March 15, 2007 Report Share Posted March 15, 2007 The ones that it tells you on the inside of the petrol flap. Link to comment Share on other sites More sharing options...
Mattchaps Posted March 15, 2007 Report Share Posted March 15, 2007 can't say I would have looked there for it! Link to comment Share on other sites More sharing options...
ChrisBuer Posted March 15, 2007 Report Share Posted March 15, 2007 [ QUOTE ] I am certian that all 4 tyres have not lost exactly 9 PSI each since I've had the car. The car was therefore delivered with the wrong pressures and I didn't think to check [/ QUOTE ] Well mate, I've always said that the first thing I check when I get a new car is the tyre pressures. Not one of the cars I've ever had has had the correct pressure levels upon collection. Most of the time they are totally over-inflated if anything as I think they just get the local work experience kid to pump them up until he thinks they "look" ok! Not only that, but over / under inflated tyres lead to bad handling, increased road noise and most of all uneven tyre wear! Link to comment Share on other sites More sharing options...
theshadow Posted March 15, 2007 Report Share Posted March 15, 2007 Says on the door jam of my MVK that you should run the tires at 36psi when teh car is unloaded and 40psi when it's fully laden...I usually split the difference and go for 38 psi. I do find that at 40-41 the car feels 'crisper' but seems that when the traction does run out the breakaway is more abrupt than when the pressures are slightly lower. Link to comment Share on other sites More sharing options...
