greenday Posted March 16, 2007 Report Share Posted March 16, 2007 hi, as above really.whilst in game out of the blue it will freeze and i cant do anything apart from turn it off and start again! the game in question is nfs carbon if that helps Link to comment Share on other sites More sharing options...
Snail Posted March 16, 2007 Report Share Posted March 16, 2007 I had a couple of crashes in that game too. The most common cause of crashing is overheating, so get the 360 is more fresh air, and see if that helps. Link to comment Share on other sites More sharing options...
greenday Posted March 16, 2007 Author Report Share Posted March 16, 2007 hi, the xbox has plenty of air and doesnt even get hot so overheating is out!! its bloody annoying when half way through a race tho'! Link to comment Share on other sites More sharing options...
sbgwz Posted March 18, 2007 Report Share Posted March 18, 2007 definatley a large problem with the 360 if you do the following: go to you system slide on the dashbord go to memory then press X,X ,Lb, Rb, X,X - how do I know if it worked?- when you restart the game you will have to download the long painful patch... that should work but i do not know if there are any downsides to this method but i got it off a rainbow six forum and it should work with all games i havent personally tried it yet but probably will tonight. if you want to see the forum http://forums.xbox.com/9601915/ShowPost.aspx thanks Link to comment Share on other sites More sharing options...
