Collinite
Johna1
Good one SPLiiX!
The difference between the two is minimal. IMHO the 915 will give you a better finish, and has a higher carnuaba content so in theory should be more durable. Also the 915 actaully works out cheaper £ for £, although it initially costs more, you get more of it.
I put on two coats of 915 in January and it is still beading like the day I first did it.
This was the result (there was polishing/glaze prior to the wax btw):
915 is Collinite's range topping wax - it has a higher carnauba content than 476s, and gives a glossier, wetter looking finish. 476s can be used to give a clearer finish, especially if you're trying to show flake.
As said above, 845 is their easiest wax to use - they list it as their 'summer' wax, but it's still ultra durable, more so than most other manufacturer's waxes.
The #915 also gives a better finish on darker colours, it's easy to work with. 169144-ok.gif
I'll second that, works far better than 476S , AG SRP / UDS or even Megs Gold Class on my black car with a glaze underneath. Just applied my second coat yesterday for winter protection and the water beading qualities are superb.
I also swear by Wolfgang Sealant. It rocks and I use it on a Dark Green Freelander and Black A2 presently. Looks great after Red Moose Glaze too, as per Geoff's recommendation. Yet to top it with Souveran as the weather has not been good enough having done the Sealant recently before!
Have a Red Mk3 Golf to fully detail soon as replacement for the Freelander that is going up for sale, so that should really show it off!
Wash first, then do whatever Polish & Prep you require, then Glaze (if wanted) and then apply the Sealant before any Wax. You dont need to Wax on top if you dont want to but it does generally improve the finish a lot, dependant on wax of course, as the Sealant can look a little clinical compared to a wet look wax.
Hi Dibbs
LSP means last stage protection. This doesnt have to be wax it can be a polymer or resin synthetic product, a wax, or combonation of both.
You dont really need to top Wolfgang, it looks so great on its own. You would really own want to place a "beauty wax" over it to improve its looks. Something like Collinite would tame the looks of Wolfgang sealant.
Your paint is porus, if you can apply a glaze to the paintwork and this will give the paint a deeper, wetter look. On silver this great when its in the shade, a glaze like ClearKote RMG will help bring out the metalic pop.
Enjoy!!
