Matt R Posted March 20, 2007 Report Share Posted March 20, 2007 Trying to make a spreadsheet at the moment to monitor incoming calls and time/date recieved. Column A = Date/Time Column B = Telephone Number What I would like is when you type the phone number in Column B it puts the Date/Time in Column A next to it?? Anyone Help?? Link to comment Share on other sites More sharing options...
scooby_simon Posted March 20, 2007 Report Share Posted March 20, 2007 [ QUOTE ] Trying to make a spreadsheet at the moment to monitor incoming calls and time/date recieved. Column A = Date/Time Column B = Telephone Number What I would like is when you type the phone number in Column B it puts the Date/Time in Column A next to it?? Anyone Help?? [/ QUOTE ] not sure what you are asking here, but I assume you have a list of phone and date/time in another sheet and you want to query it thus... "ive a phone no, when did it get called (or called us)" If so, Use something like Vlookup. Link to comment Share on other sites More sharing options...
Matt R Posted March 20, 2007 Author Report Share Posted March 20, 2007 I want to use it for incoming call logging, but would like the spreadsheet to automatically put the date/time in Column A each time you enter the next incoming phone number! Link to comment Share on other sites More sharing options...
scooby_simon Posted March 20, 2007 Report Share Posted March 20, 2007 Ahh.... use the =now() so use the formula (in col b) something like =if(A1>1, now(),"") Because the now fuction is within the "if" it may return a Deciamal date time value, in this case just convert it via the standard date/time functions. Problem is that =now() is recalculated each time the spreadsheet is changed. There must be a way to do this, try google. Link to comment Share on other sites More sharing options...
D1MAC Posted March 20, 2007 Report Share Posted March 20, 2007 Getting the exact time in column B is the easy bit use an IF formula so if column A isn't blank the current date/time is returned (which is another formula - NOW or something similar to under date/time functions - I'm trying to jog my memory via OpenOffice Calc). So, something like =IF(A1<>"",NOW(),"") and then feed down column B, then formatting column B if necessary. The bit I'm not sure on is how best to lock it so that it doesn't update itself once a value has been entered. I know you can achieve this via cell/sheet protection but whether or not that's too mechanical (having to protect new cells every time you add a value) and whether or not it can be sorted via a macro I'm not sure/is up to you. Beaten to it!!! Link to comment Share on other sites More sharing options...
Adam Posted March 20, 2007 Report Share Posted March 20, 2007 as said all the above will just be wiped with current date when you re-open file why not just create a list of now() formulas and when the number is entered, copy paste values over the now() formula on that corresponding row? Link to comment Share on other sites More sharing options...
Matt R Posted March 21, 2007 Author Report Share Posted March 21, 2007 This works: Dim Cell As Range For Each Cell In Target With Cell If .Column = Range("B:B").Column Then Cells(.Row, "A").Value = (Now) End If End With Next Cell Link to comment Share on other sites More sharing options...
Gaunty Posted March 22, 2007 Report Share Posted March 22, 2007 Create a macro, the only command you need is: ActiveCell.Value = Now() You can then call the macro with a Ctrl+letter if you set it. Link to comment Share on other sites More sharing options...
