Headlamp Washers in Maintenance mode
charding370
Anybody happen to know how to get the headlamp washers to stay out? I heard there is a maintenance mode, maybe switch off ignition when they are spraying?
I need to fit a new cover (as it was knicked) and there is no way to fit it without the washer jet assembly being in the wash position (out) rather than retracted.
My dealer replaced a cover and did exactly what is said above.
He stood at the front of the car and grabbed the arm when it was extended while I operated the lever inside.
Was this on a MK V? It does not seem to move at all unless the spring used is stronger than the MK IV?
Yea, was a MKV.
You need to get someone to operate the washers from inside and then grab the arm when it is extended to prevent it from returning.
Did he use his fingers or some kind of tool to stop it returning?
On the other hand a mole wrench is going to chip the paintwork or worse.
Although it sounds a bit brutal if you allow the washer to descend slowly then the molegrips should be OK, although I would put a duster around the washer first to protect the bumper.
As I have never seen these operate, does the washer unit protrude a lot and at a sharp angle like 45 degress when it washes? Sounds like quite a few inches.
Guest
Reply to this topic...
  Only 75 emoji are allowed.
