Rocket_Man Posted April 8, 2007 Report Share Posted April 8, 2007 On my MkIV R32 I've found the drain/filler plugs on the gear housing but i don't have the "Secure" torx type tool to get the plugs out. Is there a filler hole at the top of the gearbox somewhere? I need to get some oil in there before i can move the car Quote Link to comment Share on other sites More sharing options...
Mook Posted April 10, 2007 Report Share Posted April 10, 2007 No, there's not. You'll need the correct sized hex to get the filler out Quote Link to comment Share on other sites More sharing options...
Rocket_Man Posted April 11, 2007 Author Report Share Posted April 11, 2007 There is under the battery (if you lean over far enough you can see it). I managed to get hold of the correct tool in the end to get the filler/level plug out, things are much easier with the right tools! Quote Link to comment Share on other sites More sharing options...
