[Audi A3/S3] Tyre wear (3.2)
MikeeB
Yes its normal on haldex equiped quattro cars for the rears to wear faster. Never seen an explanation why though.
Fair enough. Just that I thought that most of the drive went to the front wheels except when required.
When I had my urq, that used to scrub off the fronts first.
My fronts wore on the inside edge so much that I had to replace them at less than 10k, Audi did me a '4-wheel alignment' and 14k later they're worn on the inside edge again, not as bad as before but still there. The dealer tells me it's normal, they called it 'Quattro scrub'. ROLLEY~14.GIF
I replaced the rears at around 21k as I had a puncture and it wasn' t worth repairing for what little tread was left.
  • 3 weeks later...
The 3.2 runs as FWD most of the time and with the heavy lump up front the Fronts should be wearing first... fist set of mine went at 17K and that included a Front to rear swap to get them all bald at the same time. This set are going the same way.
It doesnt, its front wheel biased but most of the time the car is moving there will be an element of power sent to the rear wheels(more the harder you accelerate).
I contacted Haldex about the front/rear drive split on my 3.2, this was their answer;
"The Haldex Coupling do not have a fixed split between front and rear. On
regular driving/steady state the coupling gives around 5-10 Nm to the rear.
On a 1/7 of a wheelturn we can transfer all available torque to the rear. In
a theoretical situation with the front wheels in the air we would transfer
100% torque tro the rear within 250ms.
However it is hard giving exact times and split since it is all depending on
driving situation, temperature etc etc since we do not use a straight curve
for the torque split, we just take what you need and transfer it to the rear"
HTH
Guest
Reply to this topic...
  Only 75 emoji are allowed.
