eatmysmoke Posted April 11, 2007 Report Share Posted April 11, 2007 Hi, hope someone can help. Sometimes I connect my 42 inch plasma to my computer. How do I convert the windows desktop to 16:9 so it looks right on my tv. I use windows XP Thanks Quote Link to comment Share on other sites More sharing options...
CarMad Posted April 11, 2007 Report Share Posted April 11, 2007 You need to be able to set it to the correct 16:9 ratio for your Plasma exactly what this is depends on if its scales (Not sure what plasmas do for scaling) and if its HD or not. 1,280x720 will be 720p 1,920x1,080 will be 1080i/P Right click on your desktop and Properties and then Settings to see what your graphics card can do. Quote Link to comment Share on other sites More sharing options...
eatmysmoke Posted April 11, 2007 Author Report Share Posted April 11, 2007 Its an HD tv. It is connected through the VGA connection. My Tv is set to 16:9. The windows display looks stretched just like a 4:3 tv program would. I have looked in all my settings on my computer and can't change the windows display to 16:9. Thanks Quote Link to comment Share on other sites More sharing options...
drpellypo Posted April 11, 2007 Report Share Posted April 11, 2007 It's not 16:9 in PC terms, it's 1280x720 or 1280 by 800 (that's what my Vaio display is for the widescreen monitor,) so you need to set your resolution to one of those. It may be that your graphics card doesn't support this resolution though. Quote Link to comment Share on other sites More sharing options...
gizze Posted April 12, 2007 Report Share Posted April 12, 2007 A 42" plasma uses a 4:3 ratio resolution but on a 16:9 shape screen, it does this by using rectangular pixels. So to get the best image you have to send it its native resolution, which will most likely be 1024x768/60hz, which will give you a swuashed desktop, and then tell each app where ratio matters that you are viewing on a widescreen display or that you are viewing on a 4:3 display. So for photos tell your photo viewer you have a 16:9 screen and it should look right, on video software tell it you have a 4:3 screen but anamorphic. Or if you don't mind the desktop being a bit blurry, which you won't notice with photos, films and games anyway, just set your resolution to 1280x720. Quote Link to comment Share on other sites More sharing options...
