RNS-E and SD cards
I have purchased a Sandisk 4gb Sd card for use with the RNS-E data card slots. I have dragged and dropped a number (about 100) of mp3 music files onto the card. When I insert this into the RNS-E I get the message "Loading card....do not remove". After 10mins I am still getting this message.
Is this right and I am just being impatient or am I doing something wrong?
Any advice would be much appreciated.
Right, I have checked the formatting which is FAT32. To be absolutely sure I have reformattd the card as FAT 32, dragged and dropped about 20 mp3 files onto the card, loaded it into one of the RNS-E slots, I simply get the message "Loading....." Nothing actually happens. I have tried both slots for good measure, get the same response on both.
I use mostly 4G SD (not SDHC because they don't work) cards - formatted to FAT32.
Limitation on files/folders is 512 - that's the total of ALL files and folders (including MP3 and M3U files and all folders and sub-folders).
Other limitation is that the total path length of a file cannot be longer than 64 characters - so if you have long file names in long folder names they might "go missing".
Final known limitation is that some non-alphanumeric characters are not accepted. Characters like "!".
Try inspecting the contents of the SD card on your PC and check all the above limitations.
Thanks for al the help. My card turned outto be th SC flavour after all. Non SC cards work fine.
Since SDHC cards became available more and more people are buying them to use in their RNS-E (we all want the latest and best thing don't we?), but like murray (and many others) have found THEY DON'T WORK.
Stick to SD cards and leave the SDHC ones on the shelves ...
