VR32 Posted April 18, 2007 Report Share Posted April 18, 2007 Any of you guys (still running the standard exhaust) completed this little mod? Does it make any difference to sound/performance like it does the MkIV? Also is the process done the same way as the MkIV? Thanks in advance Link to comment Share on other sites More sharing options...
khutula Posted April 18, 2007 Report Share Posted April 18, 2007 Welcome to TSN Check out this thread towards the end of it there is a picture. Link to comment Share on other sites More sharing options...
VR32 Posted April 18, 2007 Author Report Share Posted April 18, 2007 Thanks for the reply khutula. Unfortunately couldn't see a pic at the end. I've located the pipe, but trying to remove its a different story. How hard do I have to pull, its lodged on there pretty damn tight?? So say I do get it off, is there any chance of a 'Check Engine' light coming on or is that only if the pipes not sealed tight enough? Link to comment Share on other sites More sharing options...
khutula Posted April 18, 2007 Report Share Posted April 18, 2007 Here is the picture from the other thread No idea how hard - oooh err - as I have a MKIV - sorry Link to comment Share on other sites More sharing options...
MattRS74 Posted April 18, 2007 Report Share Posted April 18, 2007 VR32, Exactly the same issue here on my MK5. The MK4 pictures appear to show a simple push on pipe - buy mine feels much more like a fitted connection i.e. theres some type of plastic connector between the flap unit and the rubber pipe. Like yourself, I don't want to end up snapping something off ! I did clamp the pipe one saturday morning - that works. Sounds awesome - but I didn't want to leave a clamp floating under the car ! Matt Link to comment Share on other sites More sharing options...
ClimberSP Posted April 18, 2007 Report Share Posted April 18, 2007 Better is to press, and so the air can pass so the pump doesnt work. You will loose some power at low revs. Link to comment Share on other sites More sharing options...
