safety69 Posted May 14, 2007 Report Share Posted May 14, 2007 I have 8l a3 and i've only just noticed that its struggling for power from 65 onwards. In 5th i can only reach 4500 rpm at 90 mph, it just wont push anymore. Can anyone please help me. Quote Link to comment Share on other sites More sharing options...
Wallachie Posted May 14, 2007 Report Share Posted May 14, 2007 Sounds like your air flow meter is caput, MAF it is known as. Cheap enough to fix, and it's a very common fault so don't worry. Quote Link to comment Share on other sites More sharing options...
safety69 Posted May 14, 2007 Author Report Share Posted May 14, 2007 Thanks Mills Quote Link to comment Share on other sites More sharing options...
safety69 Posted May 19, 2007 Author Report Share Posted May 19, 2007 I've just used my 3rd party diagnostics lead using vag-com version 311-2, and it cannot find any faults to do with the MAF. The only fault codes i got were related to the central locking. Can anyone please tell me if it would show a fault code in this situation, if not how could i be sure it is the MAF. cheers Quote Link to comment Share on other sites More sharing options...
safety69 Posted May 20, 2007 Author Report Share Posted May 20, 2007 Its a 1.6, the car in will hit top rev range in 1st to 4th gears but not top speed in the selected gears if you get me, any help much appreciated, cheers. Quote Link to comment Share on other sites More sharing options...
S3ENVY Posted May 20, 2007 Report Share Posted May 20, 2007 Do you mean that the revs will increase to their maximum but the car wont go any faster? If that is the case it sounds like it could be the clutch slipping. Quote Link to comment Share on other sites More sharing options...
fingermouse Posted May 20, 2007 Report Share Posted May 20, 2007 have you monitored the maf on a run ???? it doesn`t always show fault codes just doesnt give the right output. Havn`t done this myself but have been involved in a MAF test run Quote Link to comment Share on other sites More sharing options...
safety69 Posted May 21, 2007 Author Report Share Posted May 21, 2007 [ QUOTE ] Do you mean that the revs will increase to their maximum but the car wont go any faster? If that is the case it sounds like it could be the clutch slipping. [/ QUOTE ] Well in 1st to 4th the car will hit top rev range but not the top speed in those gears, in 5th it wont hit top rev range, stays around 4500rpm and stays around 85-90mph. Quote Link to comment Share on other sites More sharing options...
safety69 Posted May 21, 2007 Author Report Share Posted May 21, 2007 [ QUOTE ] have you monitored the maf on a run ???? it doesn`t always show fault codes just doesnt give the right output. Havn`t done this myself but have been involved in a MAF test run [/ QUOTE ] I did think of this when "Mills" quoted that faulty MAF's are common problems. But where could i find the normal figures to compare? Quote Link to comment Share on other sites More sharing options...
safety69 Posted May 21, 2007 Author Report Share Posted May 21, 2007 managed to find figures on the ross-tech website "http://www.ross-tech.com/vag-com/cars/fuel-trim.html" . It states "Specifications for normal operation are usually somewhere near +/- 10%". i just tested mine and its -19% at normal idle. Think i'll replace it anyway and see how i get on. Quote Link to comment Share on other sites More sharing options...
safety69 Posted May 27, 2007 Author Report Share Posted May 27, 2007 The MAF on my car is a Hitachi sensor, which i've been told i can replace if i phoned hitachi automotive uk. Can anyone confirm whether replacement sensors are worth it, or is it worth just changing the whole MAF meter, cost wise. Quote Link to comment Share on other sites More sharing options...
