Cigarette Lighter
lwj983
Posted in the tech thread but not many people on there, anyone know if it has an 'in line fuse'? :
Hardly a major problem but any help/ideas would be appreciated. The cigarette lighter socket in the front of my Mk4 Golf has stopped working, checked the fuse in the fuse box in the dash board (by drivers door) which is fine. I need it working for sat nav so currently using an extension through the car from the boot socket.
If its totally blown and needs replacing how much do your reckon a stealer will charge? I think it must have stopped working when I had a flat battery (left lights on.....opps) and tried to use one of those cigarette lighter jump lead things..........which didn't work, must have b*ggered it up some how. That's what I get for being lazy and not getting the jump leads out!
Cheers
Do these exist!? Is this used to recharge the battery a bit? Not to try and start the engine with? Sounds worrying to me blush.gif
Cheers for the help fellas. I've bought an extension cable to run from the boot socket to the front has a temporary fix, only £5 from Maplin....bargain. I'm preety certain the actual socket has died. I'll use the extension until I decide if to change my car, tempted by an Octavia vRS (old shape). Any views on these?
Guest
Reply to this topic...
  Only 75 emoji are allowed.
