danksy Posted June 10, 2007 Report Share Posted June 10, 2007 Does anyone know if this is a DIY job? Or can it indeed be done Quote Link to comment Share on other sites More sharing options...
craigyb Posted June 10, 2007 Report Share Posted June 10, 2007 Yes, it is sort of DIY, www.kufatec.de sell kits Quote Link to comment Share on other sites More sharing options...
TDiAvant Posted June 10, 2007 Report Share Posted June 10, 2007 Bose would be an intresting retrofit for the A6, what MY is the A6 danksy? Quote Link to comment Share on other sites More sharing options...
craigyb Posted June 11, 2007 Report Share Posted June 11, 2007 Oh yes, missed that last part. It would be a major upgrade to do BOSE in the A6. Phone = easy, BOSE = hard Quote Link to comment Share on other sites More sharing options...
danksy Posted June 12, 2007 Author Report Share Posted June 12, 2007 sorry it has DVD NAV and Bose...looking to add phone prep of some description It will be an 07 MY Quote Link to comment Share on other sites More sharing options...
stig414 Posted June 12, 2007 Report Share Posted June 12, 2007 Dead easy then, speak to Craig, he did mine and i'm well pleased with it Quote Link to comment Share on other sites More sharing options...
TDiAvant Posted June 13, 2007 Report Share Posted June 13, 2007 Nav is easy, but the Bose will require some work but it is possible. Quote Link to comment Share on other sites More sharing options...
danksy Posted June 21, 2007 Author Report Share Posted June 21, 2007 anyone got a step by step guide I have full MMI with DVD Nav and Bose, but need to fit phone prep (preferably Bluetooth!) Quote Link to comment Share on other sites More sharing options...
craigyb Posted June 21, 2007 Report Share Posted June 21, 2007 This is the Kufatec guide for the complete system, you only need to do half of this for bluetooth only. The installation of this kit should be performed only by a technician. Improper handling of this kit may damage your car and or car’s equippment. After installation, the can gateway (adress 19) must be recoded. This means: Change Bit 4 of Byte 5 to 1. Disassembly: - Turn off the car and pull out the key - Open trunk, pull out the mate - Take off the plus pole of the battery. - remove all covers under the steering wheel (3 screws at all) - unscrew the glove box (5 screws at all) - unscrew the passengers’s seat - unconnect all connectors under the passengers’s seat and pull the seat out of the car - remove all covers of the transmission tunnel (one screw in the front) - pull carefully the rear outlet nozzle out - unscrew the screw behind that nozzle and take the armrest out - pull up the car’s carpet under the passenger seat - put the box with the interface in position - remove the cover for the fuseholder in the backside of the car - pull the pink protection until the first snap on contact - put the red/white cable into Fuse S16 - connect the ground to the car’s ground - put the 10A fuse into this Fuse - the green wire must be put together with the fibre optic behind the glove box. The green wire must be soldered to pin #5 of the cd-changer connector. - put the wiring harness for the mobile phone holder into the armrest - swap the inlay of the armrest to the inlay with part# 4F0 864 981 A - the loom for the compensor / amplifier must be put into the right side of the car to the trunk - the backseats are only stuck, just pull them out. - the compensor is mounted above the fuseholder Mounting instructions for fibe optic: Be very careful with the fibre optic (FO) – do not bend/fold them. Folded fibre optic must be replaced! - put the longer FO-loom to the infotainment rack - pull the 2pole connector for the FO-connector out of the amplifier – the amplifier is on the top of this rack. - push the blue bolt out of the connector - pull the locking feature of the „FO-IN“ (there’s an arrow that directs into the connector) and remove the FO-wire - remove the protection cap of the FO-wire from the loom - put the FO-wire from the loom into the FO-IN port of the amplifier - put the shorter FO-looom to the back of the glove box - pull the connector from the cd-changer - remove the FO-Out wire – as described above for the FO-In – - put the FO-wire from the loom into the FO-Out port - the FO-loom between cd-changer and amplifier is now unused and should be left in the car. Mounting instructions for the microphone to the roof module - remove the cover from the A-pillar - uninstasll the roof module and put a thin wire into the A-pillar of the car and use this wire for getting the cable of the microphone to the roof module - put the connector of the microphone into the free connector (on the right side) Mounting instructions for GSM-Antenna: - you can only use the shark antenna - you need a to drill a whole with a diameter of 19mm - make sure you place the drill in the middle of the car - For the limousine, the distance between the glas and the middle of the hole is 14cm - remove the back cover before you drill - remove the c-pillar of the car (right hand side, only 1 torxscrew) - put the wire from the antenna to the compensor - make sure to put a piece of wood between the hole and the roof for not damaging your roof - make sure to seal the hole with silicone Reassemble all parts and connect the battery - turn on the ignition - put your mobile phone into the holder (non bluetooth-mode) - push the „Phone“-Key of the MMI-System - the phone menu will be displayed - in order to be able to use the bluetooth function, make sure to have bluetooth enabled on your phone - go into the main menu and search for new bluetooth devices - your handy will display „Audi UHV xxxx“ - Pin code is 1234 Quote Link to comment Share on other sites More sharing options...
danksy Posted June 21, 2007 Author Report Share Posted June 21, 2007 Cheers craig Get the car in 12 weeks Quote Link to comment Share on other sites More sharing options...
Merlot Posted June 22, 2007 Report Share Posted June 22, 2007 Bye bye S4 Cab? Quote Link to comment Share on other sites More sharing options...
danksy Posted June 22, 2007 Author Report Share Posted June 22, 2007 Maybe Quote Link to comment Share on other sites More sharing options...
