Tom66 Posted June 14, 2007 Report Share Posted June 14, 2007 I need to top up the oil in my 97 a4 1.9Tdi quattro saloon, i have some 10/40 semi synthetic and some 15/40 semi synthetic. What would be the best to use? I looked on the service bills and it just says semi synthetic with no mention of grade. Link to comment Share on other sites More sharing options...
PetrolDave Posted June 15, 2007 Report Share Posted June 15, 2007 Check the manual in your car what the VAG spec that the oil has to meet - then go into Halfords and read the labels. I use Castrol Edge in my RS4 - one of the few oils that meets the VAG specs required. Link to comment Share on other sites More sharing options...
Tobes49 Posted June 15, 2007 Report Share Posted June 15, 2007 Either will be fine, As long as they are a Quality oil, not this £5 a gallon stuff. Link to comment Share on other sites More sharing options...
JamieSelway Posted June 15, 2007 Report Share Posted June 15, 2007 Not that I'm going to do it, but... I had Audi Assistance out last week, and while the guy was there I asked about oil, as I need to get a bit to keep for top ups. He told me as long as it meets the "VW 504 00/506 00" or the latter "VW 504 00/507 00" specification, it should be fine. In fact he uses a "VW 504 00/506 00" spec oil made by Coopers(?) in his 2.0. Which he rekons costs £8 a gallon (You'll have to check your own viscosity of course!) Now I know you'll all start gunning for me, but he had a sheet in the van from Audi listing all makes that met the standard, so I figure it's probably kosher. My own reasoning behind not using that oil is that my baby went to a main dealer for service, and I want to maintain the same make of oil between oil changes, so I'll have to get some Castrol. If I was changing my own oil, I'd probably use something different (I've found Miller's reasonable in the past) Link to comment Share on other sites More sharing options...
