bigface Posted June 18, 2007 Report Share Posted June 18, 2007 hi i was looking to swirl remove again, is it possible to do this too often?? a mate of mine said its possible an since i only did it a few months ago i thought id ask! cheers Link to comment Share on other sites More sharing options...
RReflections Posted June 18, 2007 Report Share Posted June 18, 2007 I normally only recommend machining a car once a year. If you have access to a paint thickness gauge then that will help you know how much paint you have on the car and also how much is being removed. Most new cars have between 50 and 70 microns of clear coat, on average most de-swirls will remove 5mu (microns) so in theory you can machine the car 10 times in total, before there's none left. BUT I say in theory as unless you measure very square inch/cm there could be a low spot and so less clear coat. I would also due to this only suggest going down to a max of 50% clear coat as below this there can be slight changes in the way light is refracted. If once machined and fully deswirled the correct wash methods are used then returning swirls are going to be limited and also a lot lighter, due to this you should also then find that you'd only need to remove a couple of mu to bring it back, thus increasing the number of times it can be machined. If you can follow this well done, I know what I mean but its not always easy to put into text, hope it helps a little. Link to comment Share on other sites More sharing options...
ahaydock Posted June 19, 2007 Report Share Posted June 19, 2007 Yes as above - I would twice a year max. Link to comment Share on other sites More sharing options...
maersk Posted June 19, 2007 Report Share Posted June 19, 2007 TOO often Habits of a <font color="red"> working lifetime </font> i'm afraid - puts red pen away. Link to comment Share on other sites More sharing options...
drpellypo Posted June 19, 2007 Report Share Posted June 19, 2007 I was thinking that, but I'm hardly in a position to correct with my usertitle. Link to comment Share on other sites More sharing options...
