safety69 Posted June 18, 2007 Report Share Posted June 18, 2007 I have a 8l 1.6 1997 A3, and its struggling to pull from 60 onwards. I have tried vag-com and no faults occurred. I changed the Air Mass Meter and still it remains the same. I thought it could maybe be a blocked exhaust, but the Cat is only a year old, and the rest is a stainless steel remus system. Could it still be this how can i tell? Also another possibility is that the fuel filter is blocked, but the bottom end speed and pick up is fine. Could anyone suggest what else could be the problem. Thanks Wayne Link to comment Share on other sites More sharing options...
safety69 Posted June 20, 2007 Author Report Share Posted June 20, 2007 Most times when i accelerate, you can hear some clicking noises coming from the Cat, could it be that the Cat is faulty causing a drop in performance? Link to comment Share on other sites More sharing options...
Tobes49 Posted June 20, 2007 Report Share Posted June 20, 2007 Just get someone to rev the car up and hold your hand by the exhaust pipe, Then compare to another car and see if there is any major difference? Link to comment Share on other sites More sharing options...
safety69 Posted June 21, 2007 Author Report Share Posted June 21, 2007 tried it and seems fine, comparing it to a 1.6 focus. the clicking noise could this be the lamda, and would the lamba show a fault? Link to comment Share on other sites More sharing options...
safety69 Posted June 23, 2007 Author Report Share Posted June 23, 2007 In 4th gear for example will only hit 4500 rpm at 80 mph, and its not as quick as it used to be at getting there. Just would like some ideas of what could cause it, so i can at least suggest some problems to the garage. Link to comment Share on other sites More sharing options...
Tobes49 Posted June 24, 2007 Report Share Posted June 24, 2007 [ QUOTE ] tried it and seems fine, comparing it to a 1.6 focus. the clicking noise could this be the lamda, and would the lamba show a fault? [/ QUOTE ] The lambda shouldn't make a clicking noise and have never seen one do this, I think you need to get the ECU scanned to see what faults are stored, Try the VAG-COM section of TS Link to comment Share on other sites More sharing options...
safety69 Posted June 25, 2007 Author Report Share Posted June 25, 2007 Thanks for your help Tobes49, I have tried VAG-COM and no faults show. I was reading about non original catalytic converters and that the welds fracture. Last year i had one fitted and it does seem to make more noise than it used to, could it be reducing back pressure, causing the performance drop? Link to comment Share on other sites More sharing options...
