lorcanb Posted June 18, 2007 Report Share Posted June 18, 2007 I recently bought a polo gti,BUt its has a few prob's....Firstly behind the passenger seat,the carpet is soaked wet,so bad that when you put pressure on the carpet water rises through it(was not like this when i bought it) Secondly,one of the parker bulbs is gone,anyone ever change one themselves? Its says in the manual to contact your local dearler,but i could only imagine the price for them to do it...i have very little experience with working with xenon lights. any help would be great. thanks Link to comment Share on other sites More sharing options...
Ritey Posted June 18, 2007 Report Share Posted June 18, 2007 Welcome to TSN lorcanb Your first issue is likely to be caused by a door/window rubber not sealing properly The second issue, of changing a bulb, can be helped by looking at my post about changing them yourself here - change sidelight bulbs Link to comment Share on other sites More sharing options...
Moschops Posted June 20, 2007 Report Share Posted June 20, 2007 If you do decided to change the Xenon, be very carefull, apparently they hold an electrical charge like a TV set which has to be properly discharged. I was under the impression these lasted forever and a day? Link to comment Share on other sites More sharing options...
Ritey Posted June 21, 2007 Report Share Posted June 21, 2007 The xenon should be fine, it will be the sidelights that you can change yourself, IF YOUR CAREFUL! without any harm Link to comment Share on other sites More sharing options...
