bigface Posted June 20, 2007 Report Share Posted June 20, 2007 as im hopeing to give the car another clean this saturday an having been advised that victoria wax will last a while, i was going to use megs stage 2 to polish. is there anything better and is there something i should use between this ploish and the waxing? i want to make her look nice again cheers Link to comment Share on other sites More sharing options...
ahaydock Posted June 20, 2007 Report Share Posted June 20, 2007 I would suggest a glaze. Try CG EZ Creme or Megs 7 to help add that wet look. Also try a couple of coats of the Vics, but leave 24hrs apart between applications. Link to comment Share on other sites More sharing options...
bigface Posted June 21, 2007 Author Report Share Posted June 21, 2007 so how much of a gap between polish - glaze - wax? Link to comment Share on other sites More sharing options...
alexc Posted June 21, 2007 Report Share Posted June 21, 2007 Megs Stage 2 isn't a polish it's more of a glaze, if you want a good polish then try the Poorboys Professional polish, work reall well and doesn't leave any residue. Link to comment Share on other sites More sharing options...
drpellypo Posted June 21, 2007 Report Share Posted June 21, 2007 Stage 2 isn't fab. It's not bad, but there are better products. PB is good, as is Chemical Guys. Link to comment Share on other sites More sharing options...
bpsmith Posted June 21, 2007 Report Share Posted June 21, 2007 You cant harm using the Stage 2 as a Glaze. Not the best out there but will add to the finish after Polishing, more than not using at all. I really rate Clearkote RMG as a Glaze though if you ever want to tstep things up a little. Link to comment Share on other sites More sharing options...
