Servicing recommendations
jettadeluxe
If you don't mind driving to SW London you could try Master Techs in Morden.
I've only used them once but they didn't screw up so thats a 100% success rate! They are ex Audi/VW trained techs but have set up on their own so the hourly rate is more reasonable.
Cheers,
Gadgeteer
Cant remember what the 170k service involves but if its changing plugs/oil/filters etc. then I'd do it myself as well. Takes me about a couple of hours to do but well worth it as I go around looking for any other possible signs of concern and a quick clean up while I'm at it in those hard to reach places. grin.gif
I half inched this off audiworld. There is a way to do it without vagcom but cant find the procedure. Will have another look.
Reset with VAG-COM yourself and save $100:
1995-1997 (and maybe part of 98):
[select]
[17 - Instruments]
[Adaptation - 10]
Enter the correct channel from the list below in "Channel Number"
[Read]
The "Stored Value" is the current value for that channel.
Enter the "New" value of from the list below.
[Test]
[save]
Channel 05 should be the distance until the next Oil Service.
It is in thousands of kilometers. Let's say you want the Oil
Service light to come on in 5000 miles. That would be 8000 km.
Put the value 8 into channel 05. The "standard value" used by the US
dealers would be 12 (7500 miles).
Channel 06 should be the distance until the next In-1 Service.
Same units as above. Standard value would be 24 (15,000 miles).
Channel 07 should be the time until the next In-1. In-1 lights
up based on time or distance, whichever comes first. This is in
10's of days. Standard value would be 36 for 360 days.
Channel 08 would be time until the next In-2. In-2 is based
strictly on time. Standard value is 72 for 720 days (about two years).
