skippy1980 Posted June 21, 2007 Report Share Posted June 21, 2007 Hi, I have had a problem with my 99 Bora V5 for sometime now, the compressor will not start. I also had a fan problems which as now been resolved but still the climate control will not work. Car has been at an VAG specialist all week and they cant figure it out. Compressor will start if supplied with a direct 12v feed. however using the cas wiring which is also supplying 12v to the compressor it will not turn on. Everything has been changed to try and work this out but still no joy. My suggestion is, could i run a direct 12v feed from battery to a switch (with an inline fuse) in the cabin and then out to the compressor and operate this way to by-pass the fault to get the compressor to start. Would this be safe and would you easy done? Thanks in advance, i would give you the fault code but it doesnt relate to anything. Link to comment Share on other sites More sharing options...
the1andonly Posted June 28, 2007 Report Share Posted June 28, 2007 being a pragmatic engineer by nature(!) with caveats up to my elbows, highest parts of any body's body, i would if it were mine! the car experts will advise. Link to comment Share on other sites More sharing options...
