VRO6MO Posted June 25, 2007 Report Share Posted June 25, 2007 i dunno if this question has been asked before but would the wheels from the audi's RS4 fit onto my MK5 R32? If not, please tell me what else can be fitted onto it. Link to comment Share on other sites More sharing options...
Mook Posted June 26, 2007 Report Share Posted June 26, 2007 The offset (ET) is different and the PCD (space between the bolts) is also different. Your option is to get some adaptors, which will also act as spacers. Link to comment Share on other sites More sharing options...
Dan32 Posted June 26, 2007 Report Share Posted June 26, 2007 Aren't modern Audis and VWs the same PCD 5x112? IIRC RS32 had a B7 RS4/6 front brake setup for a bit so that would imply the pcds were the same. Different offsets though - RS4 is ET29 and MKV R is ET51. Think this means that yes they will fit with spacers but the spacers would be 22mm. There are replicas of this wheel about so probably possible to still fit something that looks the same and doesn't cost anywhere near as much as OE RS4 wheels. Link to comment Share on other sites More sharing options...
Mook Posted June 26, 2007 Report Share Posted June 26, 2007 Good call, Danno - forgot that VR06MO has a Mk5 Link to comment Share on other sites More sharing options...
