jettadeluxe Posted June 27, 2007 Report Share Posted June 27, 2007 Right, I'm fed up, its been 3 months of being messed around waiting for air compressors to come from the USA, so I'm giving up on the air-ride option and going hard slam instead. Anyone have experience of coilovers here? I'm a bit depressed since it seems only the front are coilover on the kits I've seen, because the rear is seperate shock and spring, and the springs offered only seem to give a paltry drop of 35mm? Link to comment Share on other sites More sharing options...
S4_Dan Posted June 27, 2007 Report Share Posted June 27, 2007 Ask MKONEMAN, think he has H&R coilovers fitted! Link to comment Share on other sites More sharing options...
Botang Posted June 28, 2007 Report Share Posted June 28, 2007 If it were me I'd go for the KW Variant 2 Coilovers they are 30-60mm front and 45mm rear KW Coilovers Pm me if you are interested Link to comment Share on other sites More sharing options...
jettadeluxe Posted June 28, 2007 Author Report Share Posted June 28, 2007 I've just bought some FK's from DeutchBay for £450 delivered, a bargain as the cheapest over here are around £8-900. I've had FK's before, so I know the ride will be good. Link to comment Share on other sites More sharing options...
mkoneman Posted June 28, 2007 Report Share Posted June 28, 2007 i got kw's they are stupidly good cant rate them enough, worth every 80000 penney i spent stainless bodys still mint as the day they went on, superb ride considering the fronts are right down, i got custom rear springs out back coz the 40mm rear drop was poo. should sit perfect now when the dubs go on :-) Link to comment Share on other sites More sharing options...
jettadeluxe Posted June 28, 2007 Author Report Share Posted June 28, 2007 Where'd you get your springs done? My FK's appear to have a 'mini' coilover adjustable lower spring platform, so i guess I'll have a little more drop? Link to comment Share on other sites More sharing options...
mkoneman Posted June 28, 2007 Report Share Posted June 28, 2007 if it has mini adjusters then id say just take them out if you can and it will give you a better drop Link to comment Share on other sites More sharing options...
