Coppo61 Posted August 17, 2007 Report Share Posted August 17, 2007 Hi all,hope someone out there can help. My 1.9 tdi is suffering from a lack of power and stuttering. Vw.replaced N75 solenoid,new MAFF meter, also had turbo reconditioned. VW cannot find this fault after 4 attempts any ideas please? Link to comment Share on other sites More sharing options...
kite Posted August 18, 2007 Report Share Posted August 18, 2007 Welcome... Did they charge you for the work that didn't fix the problem, Feck Sorry I have no Idea what could be causing your prob... Someone will be along soon, Godd luck Link to comment Share on other sites More sharing options...
Coppo61 Posted August 18, 2007 Author Report Share Posted August 18, 2007 They charged for first diagnostic and solenoid, the turbo and MAFF i sorted myself.I've run out of ideas as to what this problem could be. I hope your right that someone out there can possibly shed some light on this. Link to comment Share on other sites More sharing options...
Rustynuts Posted August 18, 2007 Report Share Posted August 18, 2007 Well, as it's a 1994 (I missed this first time I looked) first up is to check the rubber hose that connects to the MAP sensor. The MAP is inside the ECU (which is under the plastic cover at the base of the windscreen) and there's a long rubber hose which connects to the inlet manifold. Replace it. It'll cost a couple of quid at the most, and don't even bother investigating it. Just change it out. Link to comment Share on other sites More sharing options...
Coppo61 Posted August 18, 2007 Author Report Share Posted August 18, 2007 Cheers Rustynuts,will do that first thing monday, will let you know the result. Link to comment Share on other sites More sharing options...
Coppo61 Posted August 28, 2007 Author Report Share Posted August 28, 2007 Just been informed by VW that my EGR valve is broken.Can anyone tell me if the vacuum pipes are main dealer only? Cheers John. Link to comment Share on other sites More sharing options...
meriafel Posted August 28, 2007 Report Share Posted August 28, 2007 Following your post with interest as my daughter has the same car I think which has been very reliable, done 200k, 50k of that with a chip and still with original clutch. Is yours the first of the new model that became available in approx July 1994 with rear drum brakes? Ours is a GL Estate has had the usual window winder wires fatigue in the doors when opening which are easy to replace. These also knock out the electric sunroof also. ( VW said it needed a new sunroof motor!) I recently posted a problem with dashboard lights failing/dip-full beam switch reversing itself and rev counter failing. Fitted a new switch module which didn't cure it. It turned out to be a loose multiplug into the back of the instrument binnacle. You can imagine how many parts VW would have replaced! Please keep us posted when you find a cure to your problem and the parts/cost, it's what Tyresmoke is all about. Link to comment Share on other sites More sharing options...
meriafel Posted September 16, 2007 Report Share Posted September 16, 2007 Did you fix your problem? Was it the EGR valve? Link to comment Share on other sites More sharing options...
