MajorH Posted September 12, 2007 Report Share Posted September 12, 2007 I've just received a meguiars quick clay kit in the post (Im in Italy and Meguiars don't sell clay according to their catologue even thougth the clay has instructions in Italian on it) the bar is 50g and I have a Punto sized car to attack is this amount sufficient? Quote Link to comment Share on other sites More sharing options...
bpsmith Posted September 12, 2007 Report Share Posted September 12, 2007 You should have no problem getting the Punto done with that sized bar. Also think about cutting it in half, or even thirds, as if you drop it you have to throw it away!!! Quote Link to comment Share on other sites More sharing options...
MajorH Posted September 12, 2007 Author Report Share Posted September 12, 2007 Thanks for the advice, is there a better alternative to meguiars for clay and lubricant Quote Link to comment Share on other sites More sharing options...
steelwind101 Posted September 12, 2007 Report Share Posted September 12, 2007 Hi Major, There are a couple of new things out there including spounges and lube that work just like clay but are "more" reuseable in some respects. Megs do clay (Mild is pretty nice) in 200g pots and i would by a gallon of Last Touch as lubricant. You can even dilute that with water 50/50. Geoff Quote Link to comment Share on other sites More sharing options...
drpellypo Posted September 12, 2007 Report Share Posted September 12, 2007 Or hagve a look at the Sonus range of clays. I use them as a preferable brand to the megs ones. Quote Link to comment Share on other sites More sharing options...
Ian_C Posted September 12, 2007 Report Share Posted September 12, 2007 The only advice I'd give to a clay virgin is keep the paint surface as wet as possible and take your time! Sounds obviously, but get the car as clean as you possibly can before you commence the clay. Ian Quote Link to comment Share on other sites More sharing options...
