Lagoo
TVR Cerbera V8 & Speed 6
21 posts in this topic
heres the deal
Cerbera 4.5 V8
Engine type / Capacity (cc)
Speed Eight 75 degree alloy V8 engine / 4475
Max Power 420 bhp @ 6750 rpm
Max Torque 380 lbs.ft @ 5500 rpm
Max Speed (mph) 190+
0 - 60 mph (sec) 3.9
0 - 100 mph (sec)8.3
Price (£) 46500
Cerbera Speed Six
Speed Six 6-cylinder inline alloy engine with 4 valves per cylinder and dry sump lubrication / 3966
Max Power 350 bhp @ 6800 rpm
Max Torque 330 lbs.ft @ 5000 rpm
Max Speed (mph) 170
0 - 60 mph (sec) 4.4
0 - 100 mph (sec)10.2
Price (£) 41100
History
The TVR Cerbera began life in the early summer of 1993 as a styling exercise by TVR's team of designers, who were very quickly given the go-ahead to start building full-scale models. They sculpted the car out of full-size blocks of foam rather than being constrained by the two dimensions of a paper sketch or the dehumanising aspects of design by computer.
A handsome Grand Tourer began to take shape and it was easy to see that the car would be a winner so a running prototype was prepared for the 1993 London Motor Show. Unencumbered by endless committees, TVR was able to complete the prototype in record time and the Cerbera was unveiled at the show. It was greeted with tremendous acclaim. Orders flooded in, a further 276 of them at the 1994 Birmingham Motor Show alone.
Since then, almost every aspect of the car has been improved. Originally, the Cerbera was designed to be powered by the TVR Power Rover based engines but it was decided that TVR's own engine, the Speed Eight, would be a more suitable power plant. The Cerbera was the first roadgoing TVR to feature the Speed Eight engine.
This engine is quite remarkable in design in that it owes more to the current trend in racing engines than to anything that has ever been seen before in a road car. In other words, instead of basing a race engine on an existing road engine, TVR have developed an engine for the Cerbera out of a race engine. The result is that the Speed Eight has many features in it which would be more commonly found on an F1 engine. Examples of these are its extremely sophisticated water circulation system, its lubrication system which delivers oil at high pressure to the engine and at low pressure to the crankshaft and a block so rigid that it can be used as a stressed member. An all alloy engine with its eight cylinders arranged in a 75 degree Vee, the Speed Eight engine has more torque in its various specifications than any other normally aspirated petrol engine of equivalent size and weight.
At 121 kg, the engine is indeed lighter than the V8 F1 and F3000 engines with which it shares so many features. Many Speed Eight engine components are of extremely high quality such as the pistons and connecting rods, which are forged, and the camshafts, which are rifle-bored and are made of solid billet EN40B steel. The net result is that the Speed Eight has performed extremely well in the most gruelling test known to engineers: to give forty of them to TVR Tuscan racing drivers to try to blow up every weekend for the past five seasons.
Although sharing styling cues with the Chimaera, the Cerbera is a completely new car with new brakes, chassis, suspension and a different construction method. Introduced in response to overwhelming customer demand for a 2+2, the Cerbera has seen TVR return to a market sector that it has not inhabited since 1985. With the Cerbera's interior, TVR have discarded conventional thinking and have created a dashboard binnacle in which all the instruments are right in front of the driver. The clock and the fuel gauge, visible through the steering wheel, and a fresh air vent are situated under the steering column and are adjustable for reach and rake with it. Mounted on the steering wheel are controls for the main beam, windscreen washers and wipers as well as the horn.
The Cerbera is more than a normal 2+2 in that, in terms of the configuration of its seating arrangement, it would be better described as a 3+1. The front passenger seat is able to slide forward further than normal, thereby freeing a substantial amount of extra legroom for the passenger sitting directly behind. Attention has been paid to the ease of access to the rear seats which in too many 2+2s is unnecessarily difficult. Therefore, the Cerbera's doors are long enough to make getting into the back seats much easier.
Cerbera is pronounced Sir - burr - uh and is derived from the mythological beast, Cerberus, who was the brother of the Chimaera. In addition, in Italian, una cerbera is a frightening, fierce woman.
The Cerbera actually comes with three different engines. The Cerbera Speed Six was the first car to be fitted with TVR’s own straight six and has softer suspension and higher profile tyres to give a more comfortable ride and less road noise in line with its grand touring design. Very much in the tradition of British sports cars of the sixties but with modern abilities, the Cerbera Speed Six is a coupe with a very British, very sporting nature.
The Cerbera 4.2 remains in production for those customers who prefer a V8 and the Cerbera 4.5 gives a range topping 420 bhp and 380 ft.lbs. of torque. Getting to 60 mph in 3.9 seconds, 100 in 8.1 and 150 in 17.9, the Cerbera 4.5 is one of the fastest road cars in existence. With larger brakes, modified suspension and larger wheels and tyres, the Cerbera 4.5 offers the handling and braking to match its performance, stopping from 100 mph in only 3.8 seconds. The 4.5 Cerbera also includes a Hydratrak speed sensitive differential as standard.
For the 2000 model year, lights, A pillars, roofline and seats were changed and lightweight bonnet, doors and bootlid were introduced on the Cerbera 4.5. In 2002, the headlight housings were faired into the wings for even smoother lines at the same time as the suspension being upgraded.
For 2002, all TVR Cerberas now have a new suspension set-up, the most notable parts of the which are gas-filled dampers which TVR has developed in conjunction with HBE to incorporate a highly unusual damper curve. By ramping up the rebound very quickly at higher piston speeds, traction and ride can be improved at the same time as high-speed body control.
It is also now possible for customers to have a red rose conversion for any TVR Cerbera 4.5. It gives 440 bhp at 7250 rpm and 390 ft.lbs. at 5500 rpm (up from 420 bhp at 6750 rpm and 380 ft.lbs at 5500 rpm). With reshaped inlet and exhaust ports to increase the flow of gases and a higher compression ratio giving about 50% of the improvement, the rest is only available when using 97 octane super unleaded petrol. The red rose conversion actually has a dashboard mounted switch to control which fuelling and ignition map is used to enable the engine to take advantage of the higher octane fuel while avoiding detonation when using the more easily available lower octane fuel.
Friggin gorgeous!! Any idea where we can get pics of the interior? Saw a Tuscan Speed Six 'bout a year ago, bought by an American over here.... ooo.gif DAMN!! cool.gif
I'll check it tonight at home if I get a chance. Thanks though Dude grin.gif
there is something wrong,
i saw the pic an hour ago (a yellow TVR)
and now it's gone....
so most be something wrong with the pic hosting?
Odd, I've been able to see the Yellow one up top, but the 2nd pic you posted has been the "red X of Doom" from to get-go confused.gif
i see 5 naked ladies where the piccies should be....
you wnat to see a cerbera going FAST here is a inside picture for you! jump.gifFIREdevil.gif
Lagoo, wasn't that the speed we were doing when i was on that coppers tail? jump.gif
YEA jeramy C he organises a BIG TVR metting called SURRY RUN which i went on teh last one SURRY RUN 3 and that wass good !
P.S that pic was takeng at Bruntingthorpe Track day couple pof weeks ago that i went to too! smirk.gif
