jhal
check engine light
5 posts in this topic
hi all,
06 Gti.
just recently serviced, Wed.
60K Miles, plugs changed too.
DSG oil change.
car running fine since, went to the shops this morning. didnt drive it hard.
came out of shops, started car, was about 50 feet down the road when i noticed the check engine light was on.
turned around and went back to car park.
turned her off for 5 mins. key out. then restarted it, light still on.
opened bonnet, no unusual sounds, apart from the normal ones.
put hand to exhaust, no unusual smells.
drove it home, about 8 miles, all ok. did not drive it hard.
it does not feel down on power, but didnt want to give it the berries in case.
the book says its an exhaust issue, o2 sensor.
any thoughts.
the car has been mapped, but that was about 2-3 months ago.
it also had its DV replaced around that time, was it was no boosting properly
nothing but E5 in it.(maxol petrol)
there is a local who has a vagcom, gonna pop over to him and see whats what.
i presume its ok to drive on short stints.
thanks.
james
More than likely your sensor has gone bad...
It's an easy fix if that's the problem.
got a local guy to do a download and clear the error
anyone know how to read this stuff?
Sunday,30,August,2009,17:38:05:20000
VCDS Version: Beta 907.2
Data version: 20090726
Chassis Type: 1K0
Scan: 01 02 03 08 09 15 16 17 19 25 37 42 44 46 52 56
VIN: removed Mileage: 94320km/58607miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: Malfunction 1010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 1010
Address 01: Engine Labels: 06F-907-115-AXX.lbl
Part No SW: 1K0 907 115 J HW: 1K0 907 115 F
Component: 2.0l R4/4V TFSI 0030
Revision: --H14--- Serial number: VWZ7Z0F349
Coding: 040300031C070060
Shop #: WSC 00191 264 15243
3 Faults Found:
012599 - Intake Manifold Runner Control: Basic Setting not Completed
P3137 - 001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 0
Fault Frequency: 2
Mileage: 94231 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 86.0°C
Temperature: 42.0°C
Absolute Pres.: 990.0 mbar
Voltage: 12.192 V
001602 - Sensor Reference Voltage A: Circuit: Low
P0642 - 002 - Lower Limit Exceeded - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10100010
Fault Priority: 0
Fault Frequency: 2
Mileage: 94231 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 57.0°C
Temperature: 51.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 12.319 V
001089 - EVAP Emission Control Sys: Incorrect Flow
P0441 - 002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 0
Fault Frequency: 1
Mileage: 94306 km
Time Indication: 0
Date: 2000.00.00
Time: 17:10:11
Freeze Frame:
RPM: 842 /min
Load: 21.2 %
Speed: 0.0 km/h
Temperature: 88.0°C
Temperature: 30.0°C
Voltage: 14.351 V
Readiness: 0000 0000
Address 02: Auto Trans Labels: 02E-300-0xx.lbl
Part No SW: 02E 300 043 C HW: 02E 927 770 AE
Component: GSG DSG 070 1111
Revision: 04507000 Serial number: 00000602111031
Coding: 0000020
Shop #: WSC 01279 785 00200
No fault code found.
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AA HW: 1K0 907 379 AA
Component: ESP FRONT MK60 0102
Revision: 00H13001
Coding: 0004738
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No: 1K0 907 044 BD
Component: ClimatronicPQ35 090 0808
Shop #: WSC 00000 000 00000
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 E HW: 3C0 937 049 E
Component: Bordnetz-SG H37 1002
Revision: 00H37000 Serial number: 00000005369640
Coding: E58D0F2700041500001400001400000000087F075C
Shop #: WSC 00000 785 00200
Part No: 1K2 955 119 C
Component: Wischer VW350 013 0402
Coding: 00063445
Shop #: WSC 00000
Part No: 1K0 955 559 T
Component: RegenLichtSens 011 1110
Coding: 00207646
Shop #: WSC 00000
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 R HW: 1K0 909 605 R
Component: 38 AIRBAG VW8 018 2200
Revision: 02018000 Serial number: 0038MD08W628
Coding: 0013112
Shop #: WSC 01269 785 00200
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 AG HW: 1K0 953 549 AG
Component: J0527 034 0070
Coding: 0012112
Part No: XXXXXXXXXXX
Component: E0221 002 0010
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No: 1K6 920 962 D
Component: KOMBIINSTRUMENT VDD 4312
Coding: 0003403
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 F HW: 1K0 907 951
Component: Gateway H10 0120
Revision: H10 Serial number: 280010621606D0
Coding: 3F0F0348070003
Shop #: WSC 00908 210 72116
2 Faults Found:
01300 - Control Module for Navigation with CD-Rom (J401)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 4
Reset counter: 6
Mileage: 93932 km
Time Indication: 0
Date: 2000.00.00
Time: 16:24:59
01304 - Radio
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 6
Mileage: 93932 km
Time Indication: 0
Date: 2000.00.00
Time: 16:24:59
Address 25: Immobilizer Labels: 1K0-920-xxx-25.lbl
Component: IMMO VDD 4312
Address 37: Navigation (J0506) Labels: 1T0-035-680.lbl
Part No SW: 1T0 035 680 A HW: 1T0 035 680 A
Component: RNS-MID H04 1000
Revision: AB001001 Serial number: VWZ6Z7G7347085
Coding: 000004000000000000
ASAM Dataset: ------------------------- ------
2 Faults Found:
01042 - Control Module; Not Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 5
Fault Frequency: 197
Reset counter: 222
Mileage: 88416 km
Time Indication: 0
00862 - Antenna for GPS Navigation (R50/R52)
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 254
Reset counter: 223
Mileage: 88437 km
Time Indication: 0
Date: 2000.00.00
Time: 18:24:03
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX2.lbl
Part No: 1K0 959 701 L
Component: Tuer-SG 024 2814
Coding: 0000566
Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
Part No: 1K2 909 144 K
Component: EPS_ZFLS Kl.5 D06 1701
Address 46: Central Conv. Labels: 1K0-959-433-MIN.clb
Part No: 1K0 959 433 AJ
Component: KSG 0401
Coding: 11C802087F2D8405485AC69010CC
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Part No: 1K0 907 719 C
Component: Neigungssensor 005 0003
Part No: 1K0 951 177 A
Component: Innenraumueberw.005 0202
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX2.lbl
Part No: 1K0 959 702 L
Component: Tuer-SG 024 2474
Coding: 0000566
Address 56: Radio (J0506) Labels: 1T0-035-680.lbl
2 Faults Found:
000 - -
Freeze Frame:
Fault Priority: 5
Reset counter: 222
Mileage: 88416 km
Time Indication: 0
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Reset counter: 223
Mileage: 88437 km
Time Indication: 0
Date: 2000.00.00
Time: 18:24:03
End ---------------------------------------------------------------------
yeah, they have been there for a while.
more concerned with the engine faults.
checked that ross tech site earlier.
while it give an explination for the code, its not very clear.
