naresharora Posted February 21, 2012 Report Share Posted February 21, 2012 I have a VW Polo 2002 1.4 16 V which has been giving yellow coloured engine check sign for 2 months. I had taken it to a garage and with the computer, they have diagnosed the following:- Code VAG 5 digits - 17604 Code EOBD: P 1196 Location of the failure: Oxygen heated sensor 1, bank 1, heater circuit failure Probable cause: cabling, oxygen-heated sensor. Please help. Link to comment Share on other sites More sharing options...
Cuprabob Posted February 21, 2012 Report Share Posted February 21, 2012 From that it looks like either the lambda probe is damaged or there is a bad connection to it. Did the garage not offer to replace it for you? Is the car running OK? Link to comment Share on other sites More sharing options...
naresharora Posted February 22, 2012 Author Report Share Posted February 22, 2012 Many thanks for your response. Garage does not have the spare parts and have asked me to buy myself from South Africa. Car is running fine without any problems. The only thing I have noticed that ever since the yellow light is coming, my AC is not working properly meaning it would work for 15 minutes and start giving very hot air as if we have started the heating. Does the yellow light and the AC not functioning have any connection? Thanks for your help. Link to comment Share on other sites More sharing options...
Cuprabob Posted February 22, 2012 Report Share Posted February 22, 2012 Many thanks for your response.Garage does not have the spare parts and have asked me to buy myself from South Africa. Car is running fine without any problems. The only thing I have noticed that ever since the yellow light is coming, my AC is not working properly meaning it would work for 15 minutes and start giving very hot air as if we have started the heating. Does the yellow light and the AC not functioning have any connection? Thanks for your help. No real connection between AC and yellow light. If there was a problem with AC it should als flag a fault against that controller Link to comment Share on other sites More sharing options...
