tatu
c5 s6 avant no servotronic
2 posts in this topic
Hello does anyone know if servotronic was an option on the 2002 S6 avant , my wife's has recently felt a bit stiff in the steering so i decided to check it through .According to Elsawin its controlled by unit J236 in position 13 of the relay box under the drivers side lower dash panel , i don't think the lower dash panel has ever been off . I was surprised to find no relay and no wires to postion 13 fitted by the factory . I thought the servotronic was standard ? or was delete an option ? Thanks
Can't give you a definitive answer but are you checking in Elsawin for the correct version. Audi has an annoying habit of changing the location of fuses and relays depending on whether the car is left or right hand drive
