carlhelv Posted January 25, 2005 Report Share Posted January 25, 2005 Hi I have a MKIII GL TD which has a locked boot (doesnt open with the key) and the drivers central locking doesnt work from the key but does if you lock from the drivers side and does lock if you push down the lock from inside the car. can you advise on the following 1.Release the boot that is locked and cant open with the key (not siezed) barrel moves but doesnt unlock 2.Get the drivers door key to lock and unlock all the doors. note:the drivers door central locking only started to stop working after I kept locking and unlocking to try and free up the locked boot. could it be a relay problem or something come off on the driver\boot barrel inside ??? please help !!! Link to comment Share on other sites More sharing options...
carlhelv Posted January 25, 2005 Author Report Share Posted January 25, 2005 Hi I have a VW GOLF MK3 GLTD which has a locked boot (doesnt open with the key) and the drivers central locking doesnt work from the key but does if you lock from the drivers side and does lock if you push down the lock from inside the car. can you advise on the following 1.Release the boot that is locked and cant open with the key (not siezed) barrel moves but doesnt unlock 2.Get the drivers door key to lock and unlock all the doors. note:the drivers door central locking only started to stop working after I kept locking and unlocking to try and free up the locked boot. could it be a relay problem or something come off on the driver\boot barrel inside ??? please help !!! [/ QUOTE ] Link to comment Share on other sites More sharing options...
