gb110430 Posted November 12, 2007 Report Share Posted November 12, 2007 if so how much by, fast, slow, is it a case of quickly on the accelerator to get control??? Link to comment Share on other sites More sharing options...
Wallachie Posted November 12, 2007 Report Share Posted November 12, 2007 Yes, just like a manual car would if you had the clutch in. Either use the accelerator or the handbrake to hold you. Link to comment Share on other sites More sharing options...
gb110430 Posted November 12, 2007 Author Report Share Posted November 12, 2007 can u be quick enough to step on accelerator and stop it rolling Link to comment Share on other sites More sharing options...
Biscuits Posted November 12, 2007 Report Share Posted November 12, 2007 It's been a while since I've driven a mates, but I thought it crept forward when in Drive... a la Automatic style. Maybe wrong though. Link to comment Share on other sites More sharing options...
gb110430 Posted November 12, 2007 Author Report Share Posted November 12, 2007 apparently not which was a surprise to me but it snot really as it works on two clutches which when on brake are like a clutch depressed still don't understand why it rolls though.....just seems dangerous Link to comment Share on other sites More sharing options...
Cagey Posted November 12, 2007 Report Share Posted November 12, 2007 I think it has hill-hold function - perhaps it only kicks in on certain gradients. I don't get to drive mine enough to notice... Link to comment Share on other sites More sharing options...
CarMad Posted November 12, 2007 Report Share Posted November 12, 2007 DSG does roll backwards a little bit, if you put it into drive and press the brake it will take the bit up on the clutch. Take your foot of the brake and it normally if its not a big hill will then pull forward. As with a manual clutch you might have to hold the handbrake a little and give it a little gas. On models fitted with hill hold when it works you will have no problem. On the diesels the clutch doesn't seem to work as well as on the manuals, it struggles with the torque sometimes. If you have a look in the Reviews section a few pages in there is a review about how it works there, ditto look in the GTI forum for loads of DSG related info. Link to comment Share on other sites More sharing options...
RedRobin Posted November 18, 2007 Report Share Posted November 18, 2007 DSG (on the Mk5 GTI) doesn't roll back unless the incline is very steep and then it's really easy to control with a tiny bit of throttle - Providing the car behind you isn't far too close! 'Hill Assistant' as it's called is standard and works well. Link to comment Share on other sites More sharing options...
