does the DSG roll back on hills ??
gb110430
DSG does roll backwards a little bit, if you put it into drive and press the brake it will take the bit up on the clutch. Take your foot of the brake and it normally if its not a big hill will then pull forward. As with a manual clutch you might have to hold the handbrake a little and give it a little gas.
On models fitted with hill hold when it works you will have no problem. On the diesels the clutch doesn't seem to work as well as on the manuals, it struggles with the torque sometimes.
If you have a look in the Reviews section a few pages in there is a review about how it works there, ditto look in the GTI forum for loads of DSG related info. 169144-ok.gif
