Playstation Firmware v2.30 now available
Sparky
Work on the PS Store has been completed and the firmware update is available. The update is primarily to localise the PS Store so that it is no longer HTML based and will allow faster access to the revamped system. The new store should be available once you have upgraded your PS3’s firmware.
Also included in the upgrade is improved sound technology:
DTS-HD Master Audio is literally bit-for-bit identical to the studio master recording and makes movie soundtracks and sound effects truly come to life. The technology delivers audio at the incredibly high rate of 24.5 mega-bits per second (Mbps) on Blu-ray disc, which is significantly higher than standard DVDs. DTS-HD Master Audio also offers 7.1 audio channels at 96k sampling frequency/24 bit depths, so you’ll be totally immersed in the sound. The firmware update will add DTS-HD High Resolution Audio as well, which is a similar output technology that requires less disc space.
Source
