rSAP Bluetooth Kit and craigyb
gtiller
I went over to craigyb's yesterday, and he upgraded my Phone Kit to the latest Remote SIM Access Profile system.
Couple of points:
craigyb - top bloke!
* great job
* quick
* efficient
* pain free
rSAP Bluetooth
* this is what we have been waiting for; benefits of bluetooth wireless without the drawbacks of poor signal quality or poor sound quality
* when initiated, the mobile phone basically hands over the SIM card to the car, and the car becomes the phone, using the antenna on the roof, the microphone and the MMI controls
* it reads in the phonebook too, even if there are several numbers against the same name (ie office, mobile and home numbers for the same person)
* because the car is making and receiving the calls, the battery on the mobile phone doesn't get sapped quite as quickly
The system isn't cheap, but for anyone that spends a lot of time in their car on the phone, it is well worth the investment.
Thanks again Craig for doing a top job!
www.tclsatnav.com
  • 5 months later...
Is the easy way now to fit the kit from Audi? I for one would like the rSAP facility in my car. Below is a copy from the accessories cat.
Bluetooth Remote SIM Access Profile (rSAP) cradle adaptor
The Bluetooth Remote SIM Access Profile (rSAP) cradle adaptor is an enhancement of
the factory fitted option "Mobile phone preparation - Low". It enables mobile phone
handsets to connect via Bluetooth Remote SIM Access Profile (rSAP) in the same way
as handsets connect to the factory fitted option "Mobile phone preparation - High".
The Bluetooth rSAP adaptor is fitted to the same connection as all other adaptor
cradles (either on the dashboard or in the front centre armrest). The mobile handset
is then connected to the rSAP cradle via Bluetooth. When handsets are connected,
the cradle enables the use of the external GSM car antenna and deactivates the
handset antenna in order to minimise GSM radiation in the car and handset battery
consumption. The handset is put into standby mode so battery power drain is
minimal.
Once connected, the cradle connects to the handset automatically and details of up
to four handsets can be saved. Only handsets with Bluetooth rSAP functionality are
compatible with this cradle. Details of mobile handsets that are compatible with rSAP
can be found on Audi Desktop.
Customer Benefits
- The rSAP cradle adaptor is flexible so can be used with a variety of different
handsets. This makes it future proof for compatibility with new handsets
- “Mobile phone preparation – Low” already has a Bluetooth connection but this only
operates in a mode called “Hands Free Profile”. This means that although calls can be
made and received using the car, the phones antenna and battery are operating at
full capacity when making and receiving calls. The rSAP cradle adaptor uses the cars
external antenna and power supply to make and receive calls which improves call
quality and reduces handset battery consumption.
£300.00 including VAT and fitting.
Does any one have the part number for this?
