vag-com sri reset and module labels 98 s8
RJP
Just got Vag-com today (my car talks to me!) and have a few q's:
1) I have a 98 S8, AHC, ECX, DNU, but none of the major systems is recognised by the labels in Vag-Com (see printout below). Is this usual, or have I got an odd model, or am I doing something wrong?
2) For kicks I tried to go into the service reset area and got "No adaption channel could be read or there is no information for this cluster. The SRI function will now terminate". I note that the same issue was reported recently on the Ilexa forums, but I am not a member there (yet) so could not ask them.
Thanks in advance for any pointers!
Autoscan printout is
Tuesday,29,April,2008,18:00:36:46496
VAG-COM Version: Release 704.1
Data version: 20071016
Chassis Type: 4D - Audi A8 D2
Scan: 01 03 08 11 15 16 17 18 25 35 37 45 55 56 57 65 67 75 76 77
02
Mileage: 157930km/98133miles
Address 01: Engine Labels: None
Part No: 4D0 907 557 N
Component: 4.2L V8/4V MOTR AT D01
Coding: 04373
Shop #: WSC 00097
1 Fault Found:
16705 - Engine Speed Sensor (G28): Implausible Signal
P0321 - 35-10 - - - Intermittent
Readiness: N/A
Address 03: ABS Brakes Labels: None
Part No: 4D0 907 389
Component: ABS/FDR Allrad D32
No fault code found.
Address 08: Auto HVAC Labels: None
Part No: 4D0 820 043 K
Component: D2-KLIMAVOLLAUTOMAT D05
Coding: 00081
Shop #: WSC 02324
Address 15: Airbags Labels: None
Part No: 4D0 959 655 H
Component: Airbag 7 Audi 050C
Coding: 00225
Shop #: WSC 02324
Address 17: Instruments Labels: None
Part No: 4D0 919 035 R
Component: D2-KOMBIINSTRUMENT D52
Coding: 16483
Shop #: WSC 23133
Address 25: Immobilizer Labels: None
Part No: 4B0 953 234
Component: IMMO AUZ9Z0W6024938 D03
Coding: 00000
Shop #: WSC 00097
Address 35: Centr. Locks Labels: 8D0-862-257.LBL
Part No: 8L0 862 257 G
Component: ZV-Pumpe, DWA, Funk D08
Coding: 13130
Shop #: WSC 02324
8 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
01372 - Alarm triggered by Door Contact Switch; Rear Passenger Side
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01368 - Alarm triggered by Luggage Compartment Switch
35-00 - -
01571 - Signal for Seat Memory
29-00 - Short to Ground
00955 - Key 1
09-00 - Adaptation Limit Surpassed
00956 - Key 2
Address 45: Inter. Monitor Labels: None
Part No: 8L0 951 173
Component: Innenraumueberw. D04
Coding: 00001
Shop #: WSC 00000
1 Fault Found:
01381 - Alarm triggered by Anti-Theft Sensor; Rear Right
35-00 - -
Address 55: Xenon Range Labels: 4B0-907-357-AUT.LBL
Part No: 4B0 907 357
Component: LEUCHTWEITEREGLER D001
Coding: 00008
Shop #: WSC 02324
Address 56: Radio Labels: 8D0-035-1xx-56.LBL
Part No: 4B0 035 186
Component: Radio 0001
Coding: 00407
Shop #: WSC 00000
3 Faults Found:
00852 - Loudspeaker(s); Front
36-00 - Open Circuit
00854 - Radio Display Output in dash Panel insert
49-10 - No Communications - Intermittent
01044 - Control Module Incorrectly Coded
35-00 - -
Address 02: Auto Trans Labels: None
Part No: 4D0 927 156 BL
Component: AG5 01L 4.2l4V S8RdW D03
Coding: 00101
Shop #: WSC 02324
1 Fault Found:
17087 - Brake Switch (F): Electrical Malfunction
P0703 - 35-00 - -
End --------------------------------------------------------------------------------------------------
I was advised to try the beta version. I've downloaded it but not tried the SRI yet.
Let me know how it goes. Derek at Ilexa responded quickly to an email, and I have sent him controller channel maps for the engine and hvac, so some label files may be generated for those at some point. I confirmed the service indicator information could be read (and presumably reset) manually using the adaptation feature, even if the automatic application did not work, so that is OK. The label files would be nice, but even without them I have found the program is a joy to use.
Rob
