Anyone hooked up a Sony PSP???
Strutter
Would like to play mp3s and video from my Sony PSP and Ipod.
I understand there are a couple of options for playing mp3s but can anyone tell me if there is anything out there that will allow video to be played from a PSP?
Looked at the Denison 500 but not sure if it will do the trick.
Also, I'd like to keep my CD changer if possible.
Narrow it down a bit and maybe tell us what car and audio unit you have? +++
:oGood spot! It's a 4.2 D3 on an 05 plate. Dunno the exact audio unit model but it's got sat/nav and TV.
Oh and it's silver if that helps too ;)
We dont currently do anything with the D3 so not my area of expertise, but I'm sure craigyb will be along with some advice soon....
Depends which PSP you have. If it's a slim, then it has the a/v out connection which you could have connected to the Aux input of your TV (assuming you have one).
If it's a fat, then video out is a no-go, but you could maybe rig something to feed the audio outputs in.
Cheers PsYcHe. It's a slim. Where is the aux input on the TV?
TV inputs have to be added to the TV tuner connector. It's the red 20 pin connector in the boot (left hand side) that plugs into the TV module. Normally you have to remove the DVD nav drive to get to it.
You can add two sets of phono connectors to the TV tuner for AV1 & AV2.
