Vag com codes. help?
Silverminken
i did a aouto scan and i got some error codes.
but i dont know what the problem is.
any1 have any ideas for what it can be ?
i know its in swedish but i was kind of hopping that figure11 would be kind to translate them for me =)
felkoder:
Adress 15: Krockkuddar Labels: Textfilsfel!
Artikelnr: 4D0 959 655 C
Komponent: Airbag 7 Audi D02
Kodning: 00224
Verkstad #: WSC 02314
6 Funna fel:
00656 - Sätessensor: passagerarsidan (G128)
32-10 - För hög resistans - Intermittent fel
01215 - Sätessensor bak: förarsidan (G177)
01216 - Sätessensor bak: passagerarsidan (G178)
01219 - Tändare för sidoairbag bak: förarsidan (N201)
01220 - Tändare för sidoairbag bak: passagerarsidan (N202)
00532 - Spänning
07-10 - Signal för låg - Intermittent fel
Adress 01: Motor Labels: Textfilsfel!
Artikelnr: 4D0 907 557 G
Komponent: 4.2L V8/4V MOTR HS D01
Kodning: 04213
Verkstad #: WSC 00000
4 Funna fel:
18010 - Spänningsförsörjning kl. 30: spänning för låg
P1602 - 35-10 - - - Intermittent fel
16684 - Förbränningsfeltändning lokaliserad
P0300 - 35-10 - - - Intermittent fel
16690 - 6: ans cylinder: förbränningsfeltändning lokaliserad
P0306 - 35-10 - - - Intermittent fel
16692 - 8: ans cylinder: förbränningsfeltändning lokaliserad
P0308 - 35-00 - -
Readiness: N/A
the cylinder problem on nr 6 and 8 is probably the plugs but im not sure im gonna order new ones and swicth. but i seams to be something the the electric i can figure it out.
Personally I'd clear those codes out, run the car a few days or a week and see what comes back. You have no idea how old those codes are or how relevant they are to the car as it is at the moment.
By clearing the codes you'll get a known clean starting point.
i have solved the engine problem.
but i cant figure out what wrong with the airbags.
it tells me that the passenger seat sensor has to high ressistance.
"00656 - Sätessensor: passagerarsidan (G128)
32-10 - För hög resistans - Intermittent fel" (swedish)
and i searched the wiki side u tiped me about figure11 but it wont find that specific code.
any1 got any ideas ?
This is a pretty common problem from what I understand. Mine does exactly the same thing.
If you clear it with VAG-COM, it stays away until someone sits in the seat usually. I don't think there's an easy way to do it without replacing the sensor pad, unless you can run a circuit in parallel to the existing one to reduce the resistance or smooth it out.
