Pioneer AVH P7500 in dash DVD screen. 5.1, dts + sat nav
Cappy
  • 2 weeks later...
Guys
I have decided to sell my Pioneer AVH P7500 screen because it doesnt suit my new car.
The screen is in mint condition and fully boxed with all accessories.
In my opinion, this is the best screen Pioneer has made.
One special feature with this screen is due to the way the screen come out.. it is possible to install the screen so the HU is flush with the surround. I have a matching trim ring to go with it
Alot of screens protrude by about 1" from the dash and look daft.
Awesome brushed finish. Looks cool even when closed with a piano black top with built in LCD.
Sound quality from this screen is EXCELLENT.. on par with most high end HUs..
with the big bonus that it can play DVD-A disc for the ultimate in sound. DTS, dobly digital etc capable.
It has a full compliment of SQ features such as multi channel Time alignment and 4 band parametric EQ with 9 user presets. 5 channel RCA out put (front rear + centre
Also it can play MP3s burned to CD (not burnt to dvd)
Its Region 2 coded.. but its quite easy to rip and burn your dvd region free these days so not an issue.
The screen itself is a 7" 16x9 motorised TFT touch screen with angle adjust.
It will also work with an ipod with optional ipod interface.
A full indepth technical review can be read here
http://www.caraudiomag.com/testreports/031...ayer/index.html
Basically this unit is the one! Was around £2k new..
looking for £400ono.
Additionaly, I also have the AVIC 8DVD sat nav unit which has been upraded to the AVIC 800DVD spec. (Only difference is the firmware)
Which when combined with the above screen gives you voice command and touch screen sat nav with full Postcode search and pois etc. Much better routing than personal units as it is able to track vehicle even when sat signal is lost using on board gyros.
Another bonus of the seperate nav unit.. is you dont have to keep changing discs in the screen when you want to use nav. The in dash slot remains free for use.
Looking for £200ono for that.
Also boxed as new
Sorry, I have already this model, could you tell me where to get the way to unlock region code?. Thank you.
There is no region unlock code for the unit.
What you do is burn a copy of your region coded dvd on a blank dvd (about 50p) and the region code is not copied across.
Use you copies in the car to avoid your originals getting damaged.
Amit
