mkoneman Posted October 8, 2008 Report Share Posted October 8, 2008 has anyone got a copy or know where i can get a copy of ELSA that works with vista? all the ones i can see only work on xp Link to comment Share on other sites More sharing options...
Architex mA8tey Posted October 8, 2008 Report Share Posted October 8, 2008 has anyone got a copy or know where i can get a copy of ELSA that works with vista? all the ones i can see only work on xp Ive got ELSA 3.3 + 3.4 and 3.5 upgrades and it works ok on my vista - which version are you currently using? if all else fails you can set vista to work in XP mode for that programme only on your current software but if I can help with a newer version then let me know Cheers Link to comment Share on other sites More sharing options...
harpersimon Posted October 9, 2008 Report Share Posted October 9, 2008 I have 3.51 and friend of mine says it worked on Vista once you turned the crappy USC rubbish off. Otherwise, get an XP disc.. and... :-) Link to comment Share on other sites More sharing options...
PsYcHe Posted October 9, 2008 Report Share Posted October 9, 2008 If you're reasonably technical.. A copy of VMWare workstation (available at your favourite software 'store'). Create a virtual machine with XP and then install ELSA.. Works a treat Link to comment Share on other sites More sharing options...
harpersimon Posted October 9, 2008 Report Share Posted October 9, 2008 If you're reasonably technical.. A copy of VMWare workstation (available at your favourite software 'store'). Create a virtual machine with XP and then install ELSA.. Works a treat Loving that.. in fact I think you can down load VM from MSoft for free for home use.. you can the other way around anyway (as in you can down load a Vista VM to play with ) Link to comment Share on other sites More sharing options...
A8 Doc Posted October 13, 2008 Report Share Posted October 13, 2008 Loving that.. in fact I think you can down load VM from MSoft for free for home use.. you can the other way around anyway (as in you can down load a Vista VM to play with ) VM isn't essential. A free copy of Microsoft Virtual PC works a treat as well as the Sun version too Link to comment Share on other sites More sharing options...
