Cant shut the boot!
alantong
Hi Guys,
This morning my A8 (D3) was covered in frost. I opened the boot to get some de-icer out but ever since I can not close it.
To explain better I can shut it, but its not locked / latched in any way. I can lift it up again without pressing the button or the key.
I have tried locking via the keyfob and also tried locking via the key but it makes no difference.
Any ideas what to try. I am a bit worried using the car - if I stop in a hurry the boot may fly up!
Thanks
Alan
Yes, the mechanism is open when I move the boot down. I can close the mechanism by hand but it does not latch just springs back. Fairly sure there should be some spring / pin to latch it in place.
Thx
Alan
Usually something is in the way to stop the mechanism from latching on the hook.
Check it's all aligned AND the boot release 'button' is not being activated all the time.
Thanks. Its mechnical, part of the latch in the boot lid has broken off. A new one is on order and will hopefully be easy to fit!
Alan
  • 4 weeks later...
I just had the same thing. Boot closes but doesnt latch.
Shame....you have to drive real fast to make the wind keep the boot lid down !!
Took of the boot latch and gave it an oiling but that didnt help...it was still a bit dodgy. Priced it up and it was only £27 for a dealer for a new one.
The strike plate also needed replacing as the spring from the mechanism had gone. Cant get the spring on its own from Audi....what a surprise...
So a new strike palte with the servo for soft close was fitted. £80
Works like a dream now. Just drop the boot lightly and the car does the rest.
