wuleehk Posted November 19, 2008 Report Share Posted November 19, 2008 Hi, My car is a 2001 Polo 1.6 GTI ARC. Today VAG-COM throw me the following: 3 Faults Found: 16688 - Cylinder 4: Misfire Detected P0304 - 35-10 - - - Intermittent 16705 - Engine Speed Sensor (G28): Implausible Signal P0321 - 35-10 - - - Intermittent 17796 - Control Module Malfunction - DBW Throttle Monitoring P1388 - 35-10 - - - Intermittent Readiness: 0000 0000 I used to have the 16688 as the cylinder 4 compression is lower that cyl1-3. I've my Engine Speed Sensor change 1 month ago because of the code 16705.. however this come back again And this time another 17796 which elsa tell me to replace the ECU Any ideas. Should i check something before thinking of replacing my ECU:confused: Thanks.. Link to comment Share on other sites More sharing options...
Rustynuts Posted November 20, 2008 Report Share Posted November 20, 2008 Information regarding DTC's is best sourced from the Ross-Tech Wiki. See here. Link to comment Share on other sites More sharing options...
